查看: 401|回复: 10
【分享】★☆★个人800贴纪念!
发表于 2003-11-19 00:45:19 | 显示全部楼层 |阅读模式 来自 江苏南京
借助学校文献资料查阅便利的条件,从PQDD博士论文全文库(UMI博士论文全文中国)中共查得abaqus 相关45篇,现仅上传目前个人专注的welding与residual stress方面的论文4篇,现已上传至ftp中:“/upload/CAE/ABAQUS/11.19  papers about welding &residual stress in abaqus!  by chenhu”。
这是截图,希望对相关方向的同仁学abaqus有帮助!
发表于 2003-11-19 10:59:29 | 显示全部楼层 来自 日本
回复: 【分享】★☆★个人800贴纪念!
严重祝贺,希望贴全!加分鼓励!
 楼主| 发表于 2003-11-19 13:41:36 | 显示全部楼层 来自 江苏南京
学校有监测,一次不可能批量下载,所以老大想让传哪方面的,我找找试试!截图的前四篇已传完!
发表于 2003-11-19 14:28:59 | 显示全部楼层 来自 华南理工大学
你们学校一次下载多少才不算批量下载?
关于abaqus在切削过程建立材料本构模型方面的资料有吗?
 楼主| 发表于 2003-11-19 14:33:34 | 显示全部楼层 来自 江苏南京
回复: 回复: 【分享】★☆★个人800贴纪念!
belone14 wrote:
你们学校一次下载多少才不算批量下载?
不太清楚,此前有人被警告过,所以有点怕怕!|)|)把关键词拿出来!
发表于 2003-11-19 15:20:04 | 显示全部楼层 来自 日本
先加分谢谢chenhu,不知道有没有固液耦合方面的学术和博士论文?要不麻烦你把检索到的目录贴个截图如何?
发表于 2003-11-19 15:28:01 | 显示全部楼层 来自 江西南昌
版主说的对,chenhu大侠应帖个目录给我们瞧瞧!
 楼主| 发表于 2003-11-19 16:08:13 | 显示全部楼层 来自 江苏南京
可能有点犯规,大家不易外传!
1.Crack identification in an offshore structural frame through static substructuring and finite element method.
2.Three dimensional, non-linear, finite element analysis of compactable soil interaction with a hyperelastic wheel.
3.Experimental and nonlinear FEA investigation of elbows leading to a new definition of the B(2) stress index.
4.Buckling and postbuckling analysis of stiffened composite panels in axial compression
5.The influence of material uniformity on the heat treat distortion of a steel ring.
6.Processing improvement of Moire interferometry for accurate crack-tip deformation measurement
7.Using commercial finite element code called ABAQUS in modeling hybrid constrained layers damping beam structure and  quantitative determination of the stability of implant-bone interface using resonanc...
8.An embedded-tow model for crush simulation of textile composite tube
9.Forming of tailor-welded blanks
10.Elastic-damaging plasticity model for ductile fracture
11.Modeling and management of process-induced shape distortion of sheet metal products
12.Dynamic analysis of rotor-bearing systems using three-dimensional solid finite elements
13.Modeling and optimization of superplastic forming of Weldalite(TM) 049 sheet products
14.Computational methods for determination of the effective constitutive relations of composite materials with growing cracks.
15.Constraint effects on energy absorption in unidirectional polymeric composite "MC" tubes
16.An experimental and computational investigation of dynamic ductile fracture in stainless steel welds
17.Nonlinear control of plate vibrations
18.Local buckling of tall and thin-walled high strength concrete box piers
19.Sub-frequency range stress wave factor NDE technique for assessing damage in fiber-epoxy composites
20.Modeling of shape memory alloys with plasticity
21.Numerical wing/store interaction analysis of a parametric F16 wing
22.Design sensitivity analysis and optimization of nonlinear structures with hyperelastic materials
23.Modeling of viscoelasticity and damage in composite laminates by continuum thermodynamics
24.Measurements and simulations of temperature and deformation fields in transient orthogonal metal cutting
25.Tribology of polymer films in manufacturing
26. Computer method of die design for sheet metal forming
27. Development and propagation of surface-initiated longitudinal wheel path cracks in flexible highway pavements
28. Visco-plastic constitutive model development for thermo-mechanical analysis of intumescent mat
29. Behavior of single piles embedded in elasto-plastic soil under static and dynamic lateral loading
30. Energy absorption of braided composite tubes
31. Stability analysis of slopes and footings considering different dilation angles of geomaterial
32. Impact behavior and modeling of engineering polymers.
33. A comprehensive study of gas metal arc welding process: Finite element simulations and experiments
34. The inelastic behavior of flexural members fabricated from high performance steel
35. Selective deposition of polycrystalline silicon for tuning micro-electro-mechanical resonators: Experiment and simulation
36. Development of fiber optic chemical sensors for the characterization of species transport in occluded environments.
37. Material property identification of polymer thin films under the indentation test
38. Thermal stress prediction for direct-chill casting of a high strength aluminum alloy
39. Physical modeling and finite element analysis of friction encountered in large deformation processes
40. Anisotropic poro-hyperelastic constitutive models for soft connective tissues: Application to the study of age and stress modulated fibrocartilage metaplasia in tendons
41. Thermal and shrinkage effects in high performance concrete structures during construction
42. An investigation of the development of novel piezoelectric actuator designs by fused deposition of ceramics (FDC).
43. Solution of linear elastostatic and elastodynamic plane problems by the meshless local Petrov-Galerkin method
44. Effect of residual stresses on fracture behavior of weldments
45. Developments for complex inelastic large-scale simulations and parameter estimation, with emphasis on large-strain, softening and localization phenomena
发表于 2003-11-20 07:54:25 | 显示全部楼层 来自 美国
偶可以帮助非流从UMI
下载论文, 大家通力合作
泥搞4篇,偶搞4篇, 也比较
不会引起注意.
发表于 2003-11-20 08:29:41 | 显示全部楼层 来自 大连理工大学
版主把关键词附上,我帮你下.愿为版主效劳!
发表于 2003-11-20 09:14:56 | 显示全部楼层 来自 日本
谢谢以上各位,我有困难的时候一定请大家帮忙。先在此表示感谢!
GMT+8, 2024-4-20 09:13 , Processed in 0.059243 second(s), 18 queries , Gzip On, MemCache On.
