- 5
- 2003-10-16
楼主 |
发表于 2003-11-20 14:11:32
来自 辽宁沈阳
回复: 【讨论】我在用abaqus6.4时候出现下面问题
ABAQUS JOB Deform
ABAQUS version 6.4-PR11
Begin Solver Input File Processor
11/20/2003 2:09:38 PM
Run G:\ABAQUS\6.4-PR11\exec\pre.exe
ABAQUS License Manager checked out the following licenses:
ABAQUS/Standard checked out 5 tokens.
11/20/2003 2:09:39 PM
ABAQUS Error: The executable G:\ABAQUS\6.4-PR11\exec\pre.exe
aborted with system error code 29539.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=all" to report and
save your system information. Use the same command to run ABAQUS that you
used when the problem occurred. Please contact your local ABAQUS support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
ABAQUS/Analysis exited with errors
是不是这个呀 |
