- 84
- 2003-5-22
发表于 2004-2-23 16:15:38
来自 日本
回复: 回复: 【讨论】几何非线性输出问题
ilong wrote:
还是没有解决啊,谢谢cafe版主
看得我都急了。一下信息供你参考。;)
For HyperView 6.0, the Plot client does not support plotting history data fromABAQUS ODB files.
In the Animation client, either the ABAQUS INP or ODB file can be loaded formodel data. The ODB file needs to be ABAQUS version 6.3. For direct ODB fileloading, the ABAQUS 6.3 ODB API from Altair’s distribution CD needs to beinstalled. The Altair tool AbaqusODB UpGrade updates ODB files created inABAQUS 6.2 (or earlier) to version 6.3.
When the INP file is read for model data, elements are organized into HyperViewcomponents based on section properties defined in the INP file. HyperViewdisplays all components similar to HyperMesh. Also, for INP files fromHyperMesh, component ids and colors are preserved in HyperView. In mostcases, where a corresponding INP file is available, using it over the ODB file formodel data is better.
While the ODB file has ELSETs, where each element can belong to multipleELSETs, it does not have section property information. As a result, when theODB file is read for model data, elements are organized into HyperViewcomponents based on ELSETs, where each element can belong to only one component. This can cause ‘holes’ in components.
Good luck!:I |
