如下图所示:
密闭容器的内部充压力为80MPa,其中材料2为不锈钢,其已经进入塑性,材料1为一高强度钢材,其局部也已进入塑性,试验结果表明在图上指出的地方材料1出现径向断裂,但我用ANSYS和COSMOS计算的结果都表明此处应力不高,我认为是我在计算时将其中的螺纹连接处理的不够准确,我在ANSYS中将这个地方简化为焊接了,请问这里该怎么处理啊?
另外我在COSMOS中将此螺纹连接分别处理为点对点、点对面、面对面接触,但计算的结果和处理为焊接(bonded)的结果没有大的区别。
下面附上命令流文件,请高手们帮我看看,指点一下,解决这个问题,多谢了!
/BATCH
/CWD,'E:\ansys\work'
/FILNAME,ALL-end-80-nolinear-2,0
/TITLE, model
WPSTYLE,,,,,,,,1
/PREP7
ET,1,SOLID45
ET,2,PLANE42
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,206000
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,198000
MPDATA,PRXY,2,,0.3
K,1,4,0,,
K,2,46,0,,
K,3,46,38,,
K,4,6,38,,
K,5,6,21,,
K,6,4,21,,
K,7,11,4,,
K,8,41,4,,
K,9,41,31.5,,
K,10,37,31.5,,
K,11,37,34,,
K,12,11,34,,
K,13,8,4,,
K,14,8,38,,
K,15,39,34,,
K,16,39,38,,
K, ,11,0,,
K, ,11,38,,
K, ,41,0,,
LSTR, 1, 6
LSTR, 6, 5
LSTR, 5, 4
LSTR, 4, 14
LSTR, 14, 13
LSTR, 13, 7
LSTR, 7, 17
LSTR, 17, 1
LSTR, 17, 19
LSTR, 19, 8
LSTR, 8, 7
LSTR, 19, 2
LSTR, 2, 3
LSTR, 3, 16
LSTR, 16, 15
LSTR, 15, 11
LSTR, 11, 10
LSTR, 10, 9
LSTR, 9, 8
LSTR, 7, 12
LSTR, 12, 18
LSTR, 18, 14
LSTR, 12, 11
LSTR, 16, 18
FLST,2,8,4
FITEM,2,8
FITEM,2,7
FITEM,2,6
FITEM,2,5
FITEM,2,4
FITEM,2,3
FITEM,2,2
FITEM,2,1
AL,P51X
FLST,2,4,4
FITEM,2,7
FITEM,2,11
FITEM,2,10
FITEM,2,9
AL,P51X
FLST,2,9,4
FITEM,2,10
FITEM,2,12
FITEM,2,13
FITEM,2,14
FITEM,2,15
FITEM,2,16
FITEM,2,17
FITEM,2,18
FITEM,2,19
AL,P51X
FLST,2,5,4
FITEM,2,6
FITEM,2,20
FITEM,2,21
FITEM,2,22
FITEM,2,5
AL,P51X
FLST,2,5,4
FITEM,2,21
FITEM,2,23
FITEM,2,16
FITEM,2,15
FITEM,2,24
AL,P51X
/PNUM,KP,1
/PNUM,LINE,1
/PNUM,AREA,1
/PNUM,VOLU,1
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,ELEM,0
/REPLOT
APLOT
K, ,0,0,,
K, ,0,40,,
APLOT
FLST,2,5,5,ORDE,2
FITEM,2,1
FITEM,2,-5
FLST,8,2,3
FITEM,8,20
FITEM,8,21
VROTAT,P51X, , , , , ,P51X, ,40, ,
wpro,,-30.000000,
wpro,,-30.000000,
wpro,,-30.000000,
CYL4,19,0,4,180, , ,38
wpro,10.000000,,
wpro,10.000000,,
wpro,10.000000,,
wpro,10.000000,,
CYL4,19,0,4,-180, , ,38
VSBA, 2, 37
VDELE, 8, , ,1
VSBA, 9, 42
VDELE, 2, , ,1
wpro,-10.000000,,
wpro,-10.000000,,
wpro,-10.000000,,
wpro,-10.000000,,
wpro,,30.000000,
wpro,,30.000000,
wpro,,30.000000,
VSBA, 5, 42
VSBA, 9, 37
FLST,2,2,6,ORDE,2
FITEM,2,2
FITEM,2,5
VDELE,P51X, , ,1
FLST,2,7,6,ORDE,6
FITEM,2,1
FITEM,2,3
FITEM,2,-4
FITEM,2,6
FITEM,2,-8
FITEM,2,10
VGLUE,P51X
FLST,5,3,6,ORDE,3
FITEM,5,1
FITEM,5,3
FITEM,5,8
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
MPLIST,ALL,,,EVLT
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,4,6,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,-5
FITEM,5,10
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,6
SMRT,5
SMRT,4
SMRT,3
SMRT,2
ESIZE,1,0,
MSHAPE,0,2D
MSHKEY,0
FLST,5,3,5,ORDE,3
FITEM,5,1
FITEM,5,3
FITEM,5,-4
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VPLOT
FLST,5,3,6,ORDE,3
FITEM,5,1
FITEM,5,3
FITEM,5,-4
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VPLOT
MSHAPE,1,3D
FLST,5,4,6,ORDE,4
FITEM,5,2
FITEM,5,5
FITEM,5,8
FITEM,5,10
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VPLOT
FINISH
/PREP7
TB,KINH,2,1,5,
TBTEMP,0
TBPT,,0.001,198
TBPT,,0.0035,275
TBPT,,0.018,350
TBPT,,0.034,400
TBPT,,0.05,420
TBDE,KINH,2,,,
TB,KINH,2,1,5,
TBTEMP,0
TBPT,,0.001,198
TBPT,,0.0035,275
TBPT,,0.018,350
TBPT,,0.034,400
TBPT,,0.05,420
FINISH
/SOL
ANTYPE,0
NLGEOM,1
FINISH
/SOL
FLST,2,9,5,ORDE,9
FITEM,2,1
FITEM,2,3
FITEM,2,-4
FITEM,2,33
FITEM,2,45
FITEM,2,49
FITEM,2,-50
FITEM,2,58
FITEM,2,-59
DA,P51X,SYMM
APLOT
FLST,2,9,5,ORDE,9
FITEM,2,5
FITEM,2,14
FITEM,2,-15
FITEM,2,27
FITEM,2,31
FITEM,2,46
FITEM,2,48
FITEM,2,51
FITEM,2,-52
DA,P51X,SYMM
FLST,2,3,5,ORDE,3
FITEM,2,20
FITEM,2,54
FITEM,2,60
/GO
SFA,P51X,1,PRES,80
FLST,2,3,5,ORDE,3
FITEM,2,19
FITEM,2,21
FITEM,2,28
/GO
SFA,P51X,1,PRES,80
FLST,2,1,4,ORDE,1
FITEM,2,34
/GO
DL,P51X, ,ALL,0
FINISH |
