查看: 711|回复: 12
【分享】ABAQUS/CAE 6.5 一个不错的新功能
发表于 2004-3-30 11:17:25 | 显示全部楼层 |阅读模式 来自 北京
Model Tree功能,可以方便的管理模型的各个性质,感觉会很方便
Product: ABAQUS/CAE
Benefits: The Model Tree provides a visual description of the hierarchy of objects in a model, and it is a convenient tool for navigating and managing your models. In addition, the Model Tree provides shortcuts to much of the functionality of the main menu bar, the module toolboxes, and the various mangers.
Description: The Model Tree appears on the left side of the ABAQUS/CAE main window. For example, Figure 4–1 shows the appearance of the Model Tree after completing the cantilever beam analysis in Appendix B, “Creating and analyzing a simple model in ABAQUS/CAE: a basic tutorial for the experienced ABAQUS user,” of Getting Started with ABAQUS.
Figure 4–1 The object model tree after completing the cantilever beam tutorial.
The arrangement of the objects in the Model Tree reflects the order in which you are expected to create your model. A similar logic governs the order of modules in the module menu.
Clicking mouse button 3 over an item in the Model Tree displays a popup menu that reproduces much of the functionality of the main menu bar, the module toolboxes, and the various managers. For example, the popup allows you to switch modules, create and edit objects, and suppress and resume objects. When you become familiar with the Model Tree, you will find that you can use it to quickly and conveniently perform most of the tasks required to create and manage your models.
You can toggle off the display of the Model Tree by selecting ViewShow Model Tree from the main menu bar. Typing [Cntrl]+T has the same effect.
Reference:
ABAQUS/CAE User's Manual
“Working with the Model Tree,” Section 3.5
发表于 2004-3-30 18:51:56 | 显示全部楼层 来自 陕西西安
回复: 【分享】ABAQUS/CAE 6.5 一个不错的新功能
与CATIA等软件比较类似了,期待中
发表于 2004-4-1 13:14:57 | 显示全部楼层 来自 甘肃兰州
6.5都有了?
好哦
发表于 2004-4-1 19:43:40 | 显示全部楼层 来自 山东济南
的确不错,这样方便多了。
发表于 2004-4-1 22:50:42 | 显示全部楼层 来自 江苏南京
sharpwhite,
可以给abaqus6.5照个相吗?
让大家也过过过瘾呀,
呵呵
 楼主| 发表于 2004-4-8 13:20:08 | 显示全部楼层 来自 北京
好,这个是CAE6.5打开第二个例题的效果,定位各种feature,material等等快多了
发表于 2004-4-8 13:54:37 | 显示全部楼层 来自 上海徐汇区
呵呵,现在说期待还早了点,慢慢等吧。。。
发表于 2004-4-8 14:12:22 | 显示全部楼层 来自 日本
看来庄老师的管理还是比较可爱的。
要不也把这个65PR4做啦。
发表于 2004-4-8 19:17:22 | 显示全部楼层 来自 北京
倒是满直观的。其他呢,还有没有?
pumahiker 该用户已被删除
发表于 2004-4-8 20:10:43 | 显示全部楼层 来自 安徽合肥
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-4-8 23:47:57 | 显示全部楼层 来自 江苏南京
这6.5不会仅对CAE做些改动吧?
发表于 2004-4-10 14:22:14 | 显示全部楼层 来自 天津滨海新区
shuai ,shuang de bu de liao.
发表于 2004-4-11 13:08:13 | 显示全部楼层 来自 陕西西安
网上有吗
GMT+8, 2024-4-20 08:05 , Processed in 0.046555 second(s), 15 queries , Gzip On, MemCache On.
