- 1
- 2004-7-22
我把面天线的中心体i-deas几何模型导入ansys(用part导入),再对它进行网格划分(et,1,shell63; esize,0.05; amesh,all),出现错误如下:
Quadrilateral element 8070 has a zero or inverted Jacobian at one of
its sampling locations. Midside nodes, if any, may be poorly
positioned.
Quadrilateral element 8070 has a pair of opposite edges that are 75.36
degrees away from being parallel. This exceeds the warning limit of
70 degrees.
Quadrilateral shell element 8019 has an unacceptable shape (cannot
normalize transformation matrix).
Quadrilateral element 8019 has an aspect ratio of 1.E+20, which
exceeds the error limit of 1000000.
只要能对这些面网格划分成四边形的,怎样网格划分都行,我只需要获取这些面的网格划分后的节点信息,我该怎么处理!在线等呀!附带中心体的导入文件 |
