这是 VM63 的 命令流
1. 理解掌握 平面 / 小球接触形式
2. 略作修改变成 轴承 的接触形式,沟道 / 小球接触形式
你们谁干完了,贴出命令流,我给他加 3 分!
- /COM,ANSYS MEDIA REL. 10.0 (05/31/2005) REF. VERIF. MANUAL: REL. 10.0
- /VERIFY,VM63
- /PREP7
- SMRT,OFF
- /TITLE, VM63, STATIC HERTZ CONTACT PROBLEM SOLVED USING CONTAC178 ELEMENTS
- /COM REF: TIMOSHENKO AND GOODIER, THEORY OF ELASTICITY, 3RD ED., ART. 140.
- ET,1,PLANE82,,,1 ! AXISYMMETRIC ELEMENTS
- ET,2,PLANE2,,,1
- ET,3,CONTA178,,4 ! NODAL CONTACT
- R,1
- RMOD,1,7,1 !CONTACT NORMAL ALONG UY
- MP,EX,1,1E3
- MP,NUXY,1,.3
- LOCAL,11,1,0,8,0 ! LOCAL CYLINDRICAL C.S. AT CENTERLINE
- K,1,8,-90 ! DEFINE KEYPOINTS
- K,2,8
- K,3,7.5,-90
- K,4,7.5
- K,5
- K,6,8,-82.65 ! PLACE KEYPOINT AND NODE AT EXPECTED CONTACT RADIUS
- K,7,7.5,-82.65
- L,1,3 ! DEFINE LINES
- L,2,4
- L,6,7
- LESIZE,ALL,,,1 ! DEFINE ELEMENT DIVISIONS ON ALL EXISTING LINES
- A,1,6,7,3 ! DEFINE AREAS
- A,6,2,4,7
- A,3,7,4,5
- LOCAL,12,0,0,8,0
- ARSYM,Y,1,3,1 ! CREATE HALF-SYMMETRY MODEL
- NUMMRG,KPOI
- ESIZE,,4 ! DEFINE ELEMENT DIVISIONS ON REMAINING LINES
- LESIZE,4,,,5
- *REPEAT,2,1
- LESIZE,6,,,8,8
- LESIZE,7,,,8,(1/8)
- LESIZE,10,,,1
- *REPEAT,2,2
- LESIZE,9,,,6,.2
- TYPE,1 ! CREATE NODES AND ELEMENTS
- AMESH,1,2,1
- AMESH,4,5,1
- TYPE,2
- AMESH,3,6,3
- CSYS,0
- N,1001,-1,1E-8 !NODE 1001 IS THE GROUND
- D,1001,ALL !X POSITION DOES NOT MATTER IN THIS CASE BECAUSE
- !THE CONTACT NORMAL IS ONLY ALONG UY
- TYPE,3
- REAL,1
- EN,205,1001,2 !USE THE SAME ELEMENT NUMBERS AS VM63 FOR POST-PROC
- EN,201,1001,4
- EN,202,1001,6
- EN,203,1001,8
- EN,204,1001,10
- EN,206,1001,31
- MODMSH,NOCHECK
- TYPE,1 ! REMOVE MIDSIDE NODES ALONG CONTACT SURFACE
- EMODIF,7,7,0
- *REPEAT,6,1
- MODMSH,CHECK
- FINISH
- /SOLU
- NSEL,S,LOC,X,-.01,.01 ! BOUNDARY CONDITIONS AND LOADING
- D,ALL,UX,0
- NSEL,R,LOC,Y,0
- D,ALL,UY,0
- NSEL,ALL
- LOAD=0
- *CREATE,LOADSTEP ! MACRO TO INCREMENTALLY APPLY LOAD
- FK,8,FY,ARG1
- SOLVE
- *END
- *DO,I,1,3
- LOAD=LOAD-10
- *USE,LOADSTEP,LOAD*6.2831853
- *ENDDO
- FINISH
- /POST1 ! POSTPROCESS
- /OUT,
- SET,3
- ESEL,,TYPE,,3
- ETABLE,RFOR,SMISC,1
- NSLE
- PRETAB,RFOR ! PRINT REACTION FORCE TO DETERMINE CONTACT AREA
- SSUM ! SUM OF REACTION FORCE
- NLIST ! LIST COORDINATES OF NODES OF CONTACT SURFACE
- PRNSOL,U,COMP ! LIST DISPLACEMENTS OF NODES
- /COM CALCULATE RATIO OF A - ACTUAL TO A - TARGET
- PI=(4*ATAN(1))
- LOAD=-(LOAD)*(2*PI)
- ATAR=(0.88*((LOAD*0.008)**(1/3))) ! A - TARGET
- *GET,EMAX,ELEM,,NUM,MAX
- *DO,ENUM,201,EMAX ! START SEARCH FROM ELEM 201
- *GET,GRFR,ELEM,ENUM,ETAB,RFOR ! FIND LAST ELEMENT IN CONTACT
- *IF,GRFR,EQ,0.0,EXIT
- *ENDDO
- ESEL,,ELEM,,(ENUM-1) ! SELECT LAST CONTACTING ELEMENT
- NSLE ! SELECT NODES ATTACHED TO SELECTED ELEMENTS
- *GET,NMIN,NODE,0,NUM,MIN
- NODX=NX(NMIN)
- NODY=NY(NMIN)
- NUX =UX(NMIN)
- NUY =UY(NMIN)
- AACT=NODX+NUX ! A - ACTUAL
- YCHK=NODY+NUY
- RATA=(AACT/ATAR) ! RATIO
- *status,parm
- *DIM,LABEL,CHAR,1,2
- *DIM,VALUE,,1,3
- LABEL(1,1) = ' A,'
- LABEL(1,2) = ' mm '
- *VFILL,VALUE(1,1),DATA,1.010
- *VFILL,VALUE(1,2),DATA,AACT
- *VFILL,VALUE(1,3),DATA,ABS(AACT/1.010)
- /COM
- /OUT,vm63,vrt,,append
- /COM,---------------------------------------------------------------------------
- /COM,----------VM63 RESULTS COMPARISON (OBTAINED USING CONTACT178 ELEMENTS)-----
- /COM,
- /COM, | TARGET | ANSYS | RATIO
- /COM,
- *VWRITE,LABEL(1,1),LABEL(1,2),VALUE(1,1),VALUE(1,2),VALUE(1,3)
- (1X,A8,A8,' ',F10.3,' ',F10.3,' ',1F5.3)
- /OUT
- FINISH
- *LIST,vm63,vrt
复制代码 |
