- 86
- 2004-12-22
发表于 2004-12-22 23:11:51
来自 陕西西安
Re:【原创】GUI启动画面制作的另一途径
贴出来:
function splash(filename,varargin)
%SPLASH(FILENAME,FMT,TIME) creats a splash screen using image from the
% file specified by the string FILENAME, where the string FMT specifies
% the format of the file, and TIME is the duration time of the splash
% screen in second. If the file is not in the current directory or in a
% directory in the MATLAB path,specify the full pathname of the location
% on your system. If SPLASH cannot find a file named FILENAME, it looks
% for a file named FILENAME.FMT.
% Supported file types
% JPEG Any baseline JPEG image; JPEG images with some
% commonly used extensions; 8-bit and 12-bit lossy
% compressed RGB and grayscale images; 8-bit and 12-bit
% lossless compressed RGB images; 8-bit, 12-bit, and
% 16-bit lossless compressed grayscale images
% TIFF Any baseline TIFF image, including 1-bit, 8-bit, and
% 24-bit uncompressed images; 1-bit, 8-bit, and 24-bit
% images with packbits compression; 1-bit images with
% CCITT compression; 16-bit grayscale, 16-bit indexed,
% and 48-bit RGB images; 24-bit and 48-bit ICCLAB
% and CIELAB images; 32-bit and 64-bit CMYK images; and
% 8-bit tiled TIFF images with any compression and colorspace
% combination listed above.
% GIF Any 1-bit to 8-bit GIF image
% BMP 1-bit, 4-bit, 8-bit, 16-bit, 24-bit, and 32-bit uncompressed
% images; 4-bit and 8-bit run-length encoded (RLE) images
% PNG Any PNG image, including 1-bit, 2-bit, 4-bit, 8-bit,
% and 16-bit grayscale images; 8-bit and 16-bit
% indexed images; 24-bit and 48-bit RGB images
% HDF 8-bit raster image datasets, with or without an
% associated colormap; 24-bit raster image datasets
% PCX 1-bit, 8-bit, and 24-bit images
% XWD 1-bit and 8-bit ZPixmaps; XYBitmaps; 1-bit XYPixmaps
% ICO 1-bit, 4-bit, and 8-bit uncompressed images
% CUR 1-bit, 4-bit, and 8-bit uncompressed images
% RAS Any RAS image, including 1-bit bitmap, 8-bit indexed,
% 24-bit truecolor and 32-bit truecolor with alpha.
% PBM Any 1-bit PBM image. Raw (binary) or ASCII (plain) encoded.
% PGM Any standard PGM image. ASCII (plain) encoded with
% arbitrary color depth. Raw (binary) encoded with up
% to 16 bits per gray value.
% PPM Any standard PPM image. ASCII (plain) encoded with
% to 16 bits per color component.
% See also IMFINFO, IMWRITE, IMFORMATS, FREAD, IMAGE, DOUBLE, UINT8.
%%%%%%%% Example
%%%%%%%% splash('C:\MATLAB7\toolbox\matlab\demos\html\wernerboy_01','png',3);
%%%%%%%% or splash('C:\MATLAB7\toolbox\matlab\demos\html\wernerboy_01.png',3);
%%%%%%%% or splash('C:\MATLAB7\toolbox\matlab\demos\html\wernerboy_01.png');
% Note
% Java requires uint8 data to create an instance of the Java image class,
% java.awt.Image. If the input image is of class uint8, jimage contains
% the same uint8 data. If the input image is of class double or uint16,
% im2java makes an equivalent image of class uint8, rescaling or offsetting
% the data as necessary, and then converts this uint8 representation to an
% instance of the Java image class, java.awt.Image.
% Han Qun, Sept. 2004
% Copyright 2004-2005 Han Qun
% College of Precision Instrument and Opto-Electronics Engineering,
% Tianjin University, 300072, P.R.China.
% Email: junziyang@126.com
if nargin ==1 % filename with format, defualt duration time
I = imread(filename);
time = 3;
elseif (nargin == 2)&(ischar(varargin{1})) % filename without format, defualt duration time
fmt = varargin{2};
I = imread(filename,fmt);
time = 3;
elseif (nargin == 2)&(isnumeric(varargin{1})) %filename with format, user specified duration time
time = varargin{1};
elseif nargin == 3 % filename without format, user specified duration time
fmt = varargin{1};
time = varargin{2};
if (~isnumeric(time))| (length(time)~=1)
error('INPUT ERROR: TIME must be a numeric number in seconds');
end
else
error('INPUT ERROR: Too many imput arguments!');
end
splashImage = im2java(I);
win = javax.swing.JWindow;
icon = javax.swing.ImageIcon(splashImage);
label = javax.swing.JLabel(icon);
win.getContentPane.add(label);
% get the actual screen size
screenSize = win.getToolkit.getScreenSize;
screenHeight = screenSize.height;
screenWidth = screenSize.width;
% get the actual splashImage size
imgHeight = icon.getIconHeight;
imgWidth = icon.getIconWidth;
% set the splash image to the center of the screen
win.setLocation((screenWidth-imgWidth)/2,(screenHeight-imgHeight)/2);
win.pack
win.show % show the splash screen
tic;
while toc<=time
end
win.dispose % close the splash screen |
