- 91
- 2002-9-15
发表于 2005-4-8 23:24:25
来自 台湾台北
Re:赫兹碰撞时,仿真参数的选择依据。希望对大家有用。
Briefly share my experience.
Hertz theory is only for static contact. Therefore, basically it's not applied to dynamics contact. In fact, the real stiffness varies by time for contact problem. Therefore, one simple way is adapted.
0.5*m*v^2=0.5*(K)*x^2 , you must determine x value, penetration. Then, you may try other different K values, 0.1*K,K and 10K. For rigid body system, you don't care about the very precise stiffness. Because another parameter , force exponent, will tune contact force automatically. In a word, no any theories can offer the contact stiffness evaluation nowsday. Experiment is the necessary for contact/impact problem.
J |
