- 10
- 2004-12-14
发表于 2005-1-10 16:59:36
|阅读模式
来自 上海交通大学闵行校区
我现在算一根杆件的拉伸,
材料常数如下:
弹性:E=1555E9;v=0.3
塑性: 屈服应力 屈服应变
100E9 0
200E9 0.2
500E9 0.6
1000E10 0.8
不知道这样定义塑性问题对不对?
加力计算总是出现如下的错误:
***WARNING: SOLVER PROBLEM. ZERO PIVOT WHEN PROCESSING NODE 2 INSTANCE ROD-1
D.O.F. 1
Typically a zero pivot is associated with an overconstraint in the model.
However, ABAQUS was not able to indentify any chains of constraints that might
lead to an overconstraint at this node. This suggests that the model might be
in fact insufficiently constrained in this particular degree of freedom.
Please check the constraints used in this model.
***WARNING: Solver problem. Zero pivot when processing D.O.F. 1 of 1 nodes.
The nodes have been identified in node set
WarnNodeSolvProbZeroPiv_1_2_1_5_1.
***WARNING: THE SYSTEM MATRIX HAS 1 NEGATIVE EIGENVALUES.
IN AN EIGENVALUE EXTRACTION STEP THE NUMBER OF NEGATIVE EIGENVALUES IS
EQUAL TO THE NUMBER OF EIGENVALUES BELOW THE CURRENT SHIFT POINT.
THIS MAY BE USED TO CHECK THAT EIGENVALUES HAVE NOT BEEN MISSED.
NOTE: THE LANCZOS EIGENSOLVER APPLIES AN INTERNAL SHIFT WHICH WILL
RESULT IN NEGATIVE EIGENVALUES.
IN A DIRECT-SOLUTION STEADY-STATE DYNAMIC ANALYSIS, NEGATIVE
EIGENVALUES ARE EXPECTED. A STATIC ANALYSIS CAN BE USED TO VERIFY THAT THE SYSTEM IS STABLE.
IN OTHER CASES, NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
POSITIVE DEFINITE:
FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
NEGATIVE EIGENVALUES MAY ALSO OCCUR IF QUADRATIC ELEMENTS ARE
USED TO DEFINE CONTACT SURFACES.
***WARNING: THE STRAIN INCREMENT HAS EXCEEDED FIFTY TIMES THE STRAIN TO CAUSE
FIRST YIELD AT 5 POINTS
***NOTE: THE RATE OF CONVERGENCE IS VERY SLOW. THE INCREMENT WILL BE
ATTEMPTED AGAIN WITH A TIME INCREMENT OF 1.23596E-03
***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT: ANALYSIS TERMINATED
ANALYSIS SUMMARY:
TOTAL OF 7 INCREMENTS
11 CUTBACKS IN AUTOMATIC INCREMENTATION
105 ITERATIONS
105 PASSES THROUGH THE EQUATION SOLVER OF WHICH
105 INVOLVE MATRIX DECOMPOSITION, INCLUDING
0 DECOMPOSITION(S) OF THE MASS MATRIX
1 REORDERING OF EQUATIONS TO MINIMIZE WAVEFRONT
0 ADDITIONAL RESIDUAL EVALUATIONS FOR LINE SEARCHES
0 ADDITIONAL OPERATOR EVALUATIONS FOR LINE SEARCHES
0 WARNING MESSAGES DURING USER INPUT PROCESSING
132 WARNING MESSAGES DURING ANALYSIS
85 ANALYSIS WARNINGS ARE NUMERICAL PROBLEM MESSAGES
4 ANALYSIS WARNINGS ARE NEGATIVE EIGENVALUE MESSAGES
1 ERROR MESSAGES
不知道到底出现了什么错误?请教大侠指点,谢谢! |
