- 1
- 2002-6-13
请tyqk和pp看看我的k文件,问题在哪。
*KEYWO
*TITLE
*DATABASE_FORMAT
TRANSFER SOLID MODEL BOUNDARY CONDITIONS TO FINITE ELEMENT MODEL
CONSTRAINTS TRANSFERRED FROM AREAS = 161
$ NODE DEFINITIONS $
*NODE
1 1.800000000E-01 0.000000000E+00-1.900000000E-01 0 0
...... 12295 5.036658794E-02 1.437195670E-02 8.936085701E-01 0 0
$ SECTION DEFINITIONS $
*SECTION_SOLID
1 5
*SECTION_SOLID
2 1
$ MATERIAL DEFINITIONS $
*MAT_HIGH_EXPLOSIVE_BURN
1 1.7000000 0.7530000 0.2550000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_JWL
1 5.4094000 0.0937260 4.5000000 1.1000000 0.3500000 0.0800000 0.0000000
*MAT_ELASTIC
2 0.183E+04 0.850E+09 0.278000 0.0 0.0 0.0
$ PARTS DEFINITIONS $
*PART
Part 1 for Mat 1 and Elem Type 1
1 1 1 0 0 0 0
*PART
Part 2 for Mat 2 and Elem Type 2
2 2 2 0 0 0 0
$ DISCRETE MATERIALS $
$ ELEMENT DEFINITIONS $
*ELEMENT_SOLID
1 1 110 1434 1185 1435 1435 1435 1435 1435
2 1 1436 110 1434 1185 1185 1185 1185 1185
6164 6165 6166 6167 6168 6169 6170 6171
6172 6173 6174 6175 6176 6177 6178 6179
6180
*BOUNDARY_SPC_SET
1 0 0 0 1 0 0 0
$ CONTACT DEFINITIONS $
$ CONTROL OPTIONS $
*CONTROL_ENERGY
2 2 2 2
*CONTROL_SHELL
20.0 1 -1 1 2 2 1
*CONTROL_TIMESTEP
0.0000 0.9000 0 0.00 0.00
*CONTROL_TERMINATION
0.100E-02 0 0.00000 0.00000 0.00000
*INITIAL_DETONATION
$ TIME HISTORY $
*DATABASE_BINARY_D3PLOT
0.1000E-04
*DATABASE_BINARY_D3THDT
0.1000E-05
$ DATABASE OPTIONS $
*DATABASE_EXTENT_BINARY
0 0 3 1 0 0 0 0
0 0 4 0 0 0
*END
运行i=3cc.k pr=dyna 后,在信息框出现:
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94550 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 960 Date: 07/22/2001 |
| Revision: 447 Time: 14:04:43 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Platform : PC (Intel) |
| OS Level : WINDOWS 2000 |
| Hostname : cumt |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: 3cc.k
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2001 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
LS-DYNA will perform a structural only analysis
ls-dyna (version 960 ) date 07/22/2001
*** Error *** line number 9 contains improperly formatted data
************************************************line# 9
*** Error reading 5th control card
E r r o r t e r m i n a t i o n
Storage required for explicit solution: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 2.4100E-01 100.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 2.4100E-01 100.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 1
Start time 03/07/2003 21:59:19
End time 03/07/2003 21:59:21
Elapsed time 2 seconds ( 0 hours 0 minutes 2 seconds) |
