- 9
- 2003-10-28
可以将PAM/LS-DYNA的有限元模型自动转换成MADYMO FE模型,免费模块,无需申请license。
用Perl script语言编写,用户可以自行修改源码,以适应不同的需求。
下载地址:http://www.automotive.tno.nl/smartsite.dws?id=1458
# MADYMO/Converter 1.0 April 2005 TNO MADYMO BV
MADYMO/Converter is a tool that converts datafiles from FEM packages to MADYMO
format.
If you have installed XMADgic version 4.0, you do not need to install
MADYMO/Converter separately.
The tool uses Perl scripting to convert the data. The Perl script can be
changed to adapt it to specific needs.
1. Installation
Perl installation on your system
Test if Perl has already been installed on your machine. Open a command shell
window and type the command perl. If there is no error message, and no prompt
appears, Perl runs and is waiting for input. Type <ctrl>C to exit the program.
If the program cannot be found, download it from http://www.perl.org for your
platform type.
MADYMO/Converter installation on UNIX systems
Download the following files from the MADYMO web-site:
* install_converter_10
* share.tar.gz
* <platformid>.tar.gz
<platformid> refers to the platform on which you want to install MADYMO. See
the list of supported platforms at the end of this document.
Run script install_converter_10 and follow the instructions in the script.
MADYMO/Converter installation on Windows systems
Download the following file from the MADYMO web-site:
* converter.exe
Run converter.exe and click unzip.
This puts the installation package in c:/temp.
Go to this directory in the Windows Explorer and double click on setup.exe.
Follow the instructions in the setup program.
2. Licensing
No licensing is required for this release of the MADYMO/Converter.
3. Running MADYMO/Converter
See the converter_user_guide.pdf file, which is part of the installation
package.
4. Supported Platforms
Platform platformid
IBM AIX 5.1/5.2 ibmrs51
HP-UX 11.00 PA-RISC 2.0 hp1100pa20
RedHat Linux 7.3 linux32
RedHat Linux Enterprise Ed. linux32e
SGI R10000 or higher sgi64r10k
Sun UltraSparc sun4sol26U
Sun Ultra III sun4UIII
Windows NT/2000/XP win32
