查看: 2154|回复: 15
求救在WinXP+SP2下安装I-DEAS NX10?
发表于 2005-10-13 21:54:16 | 显示全部楼层 |阅读模式 来自 重庆江北区
我的操作系统是WinXP+SP2,并装有有限元分析软件ABAQUS 6.4。
我4cd的安装盘拷贝到F盘,按照如下步骤安装I-DEAS NX10:
IDEAS安装说明:
We have install info in crack/ but these are more detailed...
1. Run autoplay.exe from CD 1 and Install Java 2 sdk.
运行CD1中的autoplay.exe,安装Java 2 (1.3.1_4) Development Environment(点右侧》)
2. Install I-DEAS 10 NX. When Prompted for an "Installation Number" type in "1".When Prompted for "Customer Information"  type in "nx10@eds.com" and click next.
安装I-DEAS 10 NX,在Installation Number中输入“1”,在e-mail中输入"nx10@eds.com",其余任意输入。
3. Click through the rest until you are prompted for a password and then   enter: 11112222-33334444-11112222-33334444-11112222-33334444-5566
在enter password中输入11112222-33334444-11112222-33334444-11112222-33334444-5566
4. After clicking next it will show a blank License Product window,  don't worry, hit next and select the component named: A501 (This option  is a full install). You may select all possible options if you wish but it is not recommended(if you install different you would need to configure some  things manually, such as flexlm and others)
继续下步到选择安装内容时选:A501(完全安装,2.9G)
5. In the next few windows select and install the docs, and the other options.
继续下一步,提示插入后续光盘时更改相应的CD2,CD3以完成安装。(CD4可不安装)
6. At the end of the installation you must reboot.
安装完成后重新启动。
7. Install the help file on CD 4. If you don't you will be nagged about the missing files.
8. Copy the eds_id10.lic & eds_id10.opt files to your "x:\eds\i-deas\sec"  directory. Edit the eds_id10.lic and change "this_host" to your computer named and change the DAEMON PATH on line 2 (both paths) to your installed path.
将CD1中的crack文件夹中的文件拷贝到安装目录中的SEC文件夹中并去掉只读属性,(如安装目录为D:\EDS\I-DEAS\,则拷贝至D:\EDS\I-DEAS\SEC目录中),编辑eds_id10.lic文件,将第一行中的this_host改为计算机名,并将下行中的文件路径改为安装路径。(如D:\EDS\I-DEAS\SEC)
9. In most cases Flexlm services should have been automatically installed. If you  are missing Flexlm services for I-Deas then you will need to manually install  them using the Flexlm applet. All the required files are located in "x:\eds\i-deas\sec"  directory.
10. Set the Flexlm License Environment (Skip this step if it is already set):
LM_LICENSE_FILE = 7610@this_host  (this_host is your computer name)
在我的电脑-属性-环境变量中增添一系统变量LM_LICENSE_FILE = 7610@this_host(this_host 为计算机名)
11. Reboot.P.S if you have trouble finding deamon edit 2nd license in license so it will read this: DAEMON eds_id10 x:\EDS\I-DEAS10\sec\eds_id10.exe options=x:\EDS\I-DEAS10\sec\eds_id10.opt    (i.e add the full path to deamon not just to the directory)
重新启动,如不能运行,需更改快捷方式ideas opengl的指向为安装目录下的BIN文件夹,(如目标改为D:\EDS\I-DEAS10\bin\I-DEASOGL.cmd,起始位置D:\EDS\I-DEAS10\bin\),在控制面板中,FLEXlm License Manager中新增ideas的服务,并配置D:\EDS\I-DEAS10\sec\lmgrd.exe,D:\EDS\I-DEAS10\sec\eds_id10.lic,D:\EDS\I-DEAS10\sec\Debug.log,加为windows服务并选启动时运行,保存退出。程序可正常使用。
 楼主| 发表于 2005-10-13 21:55:41 | 显示全部楼层 来自 重庆江北区
Re:求救在WinXP+SP2下安装I-DEAS NX10?
问题:输入密码后继续安装,出现如下对话框,正常吗?
 楼主| 发表于 2005-10-13 21:59:03 | 显示全部楼层 来自 重庆江北区
安装完cd3后出现如下对话框,按任意键后,即退出,要求重启。
重启后,配置好license却不能启动。
 楼主| 发表于 2005-10-13 22:00:33 | 显示全部楼层 来自 重庆江北区
大虾们,救命呀!
发表于 2005-10-16 22:12:45 | 显示全部楼层 来自 上海浦东新区
在盘上根目录(哪个盘都可以)建个目录,取个英文名字,把开始目录选它就应该可以了
 楼主| 发表于 2005-10-18 22:56:38 | 显示全部楼层 来自 重庆江北区
可以说得详细一点吗?什么叫“把开始目录选它"?急呀,谢谢先。
 楼主| 发表于 2005-10-20 21:40:37 | 显示全部楼层 来自 重庆北倍区
问题还没有解决。
 楼主| 发表于 2005-10-20 21:42:25 | 显示全部楼层 来自 重庆北倍区
问题还没有解决。
发表于 2005-11-4 11:35:52 | 显示全部楼层 来自 辽宁大连
程序里面的ideas起始命令,属性,起始目录I更改成一个确定的英文文件夹。
发表于 2005-12-12 16:51:10 | 显示全部楼层 来自 广东佛山
ideas建议在win2000+sp4补丁下使用。
abbot 该用户已被删除
发表于 2005-12-13 16:11:49 | 显示全部楼层 来自 江苏苏州
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-6-30 17:08:46 | 显示全部楼层 来自 江苏苏州
I-DAS技术交流QQ群41836443
有什么问题可直接答问
欢迎大家的加入
注意:在加入此群时,必须添加附加信息为:"I-DEAS爱好者"
否则将拒绝加入
发表于 2018-1-9 21:18:11 来自手机 | 显示全部楼层 来自 中国
哪位朋友把i-deas nx10发给我呀?非常感谢!邮箱:12225818@qq.com
发表于 2018-1-29 10:32:39 | 显示全部楼层 来自 广东深圳
偶也在收藏NX 10.0版本的,谁有分享一下哈。
发表于 2018-1-31 19:51:34 来自手机 | 显示全部楼层 来自 中国
把你QQ号告诉我呀
发表于 2018-5-2 18:57:10 | 显示全部楼层 来自 广东深圳
dhl181818 发表于 2018-1-31 19:51
把你QQ号告诉我呀
你好啊。我的QQ号是28124074。谢谢你的回复。盼早点收到I-DEAS10.
GMT+8, 2024-4-25 09:35 , Processed in 0.056668 second(s), 14 queries , Gzip On, MemCache On.
