- 25
- 2003-6-10
发表于 2003-10-16 14:11:39
来自 LAN
回复: 【讨论】nastran中shell单元和体单元的连接问题
请看下面的例子
http://www.mscsoftware.com/support/online_ex/n4w/N4w105/ws11_solidtoshell.pdf
Abstract:WORKSHOP 11 Shell- to- Solid Element Connector( RSSCON)MSC. WORKSHOP 11 Shell- to- Solid Element ConnectorMSC. Nastran for Windows 105 Exercise Workbo ok11- 3 The introduction of the RSSCON Shell- to- Solid connector enables MSC.
http://www.mscsoftware.com/support/online_ex/Patran/Pat323/Exercise_06_shell_solid_transition.pdf
Abstract: LESSON 6 Modeling a Shell to a Solid Element PATRAN 322 Exercise Workbook - Release 8. 06- 3 Model Description: In this exercise, you will create a solid/ surface transition. LESSON 6 Modeling a Shell to a Solid Element PATRAN 322 Exercise Workbook - Release 8. 06- 5 Click on the Show Labels icon. Material Name: m: aluminium_ iso_ SI_ mm OK Select Members: Solid 1 Add Apply Action:Create Object:2D Type:Shell Property Set Name: sur Input Properties ...
http://www.mscsoftware.com/support/library/conf/auc99/p05699.pdf
Abstract: In the current Part 3, the shell- to- solid transition interface element, being implemented to connect dissimilar p- element edges with p- element faces, is presented with examples. The first paper, Part 1 [1], described the curve interface elements implemented in Version 69 of MSC/ NASTRAN for shell and beam p- element edges. The current paper, Part 3, describes the shell- to- solid transition interface elements being implemented in MSC/ NASTRAN for solid p- element faces and shell p- ... |
