- 16
- 2002-5-28
发表于 2002-5-29 20:48:02
来自 江苏南京
回复: 【求助】MSC.安装方法
楼上的兄弟说的很对,一般的D版软件里都会有该软件的安装指导,这类的安装指导一般在CRACK目录下,以下的这段MSC.GS-Mesher安装方法也是在该软件的CRACK下面的,按照该步骤可以成功安装并运行MSC.GS-Mesher.在使用该软件的过程中发现其网格划分功能不能启动,不知为何?望各路高手予以指点。THANKS ADANCED!!!
Install GS-Mesher. Install FlexLm License, choose Server Install and choose the supplied license.dat when prompted for a license file. You might get a message saying that the License Server is incompatible with the License File, just ignore it. You might also be prompted for your hostname, fill it in. Exit setup when done.
Put the supplied license.dat in %installdir%\msc\flexlm\licenses\. Now open the license.dat with a text editor and edit the SERVER line, replace YOUR_HOSTNAME with your hostname. If you dont know your hostname you can look it up using the installed lmtools.exe program (look under System Settings). You must also edit the path to the vendor daemon on the DAEMON line (DAEMON MSC C:\msc\flexlm\msc.exe) if you didnt install in the default directory. Do not forget to save the file when you are done. Now edit your environment variables LM_LICENSE_FILE and MSC_LICENSE_FILE or create new ones if you dont already have them. Both of them should have the value %installdir%\msc\flexlm\licenses\licenses.dat.
Now start lmtools.exe found in %installdir%\msc\flexlm\. Select the "Service/License File" tab and choose "Configuration using Services" and make sure the FLEXlm License Server is selected. Go to the tab "Configure Services" and fill in the the 3 fields, when you are done it should look something like this:
Path to lmgrd.exe file : C:\MSC\flexlm\Lmgrd.exe
Path to the license file : C:\MSC\flexlm\licenses\license.dat
Path to the debug file : C:\MSC\flexlm\licenses\flexlm.log
Make sure "Start Server at Power Up" and "Use Services" are checked and save service. Now go to the "Start/Stop/Reread" tab and choose "Start Server" (if the server is running you must stop it first and then start it for changes to take effect).
Now apply the patch DODMG2R3.exe in %installdir%\MSC\GS-MESHER\Bin\, there are 6 files to patch. You can now use the program! |
