- 92
- 2003-5-19
发表于 2006-1-10 07:49:52
来自 美国
Re:【原创】使MATLAB变成中文版
发现properties文件在java类库里面使用的也非常多,有一个专门的类 Properties用来处理这种文件,而且还有一个工具来专门处理字符转换问题,如果装了jdk的话,不妨用这个工具来试试。翻译的时候直接输入中文,然后用
native2ascii file_zh file_unicode 转换一下就可以了,非常方便。
非常感谢junziyang的发现与共享。
native2ascii - Native-to-ASCII Converter
Converts a file with native-encoded characters (characters which are non-Latin 1 and non-Unicode) to one with Unicode-encoded characters.
SYNOPSIS
native2ascii [options] [inputfile [outputfile]]
DESCRIPTION
The Java compiler and other Java tools can only process files which contain Latin-1 and/or Unicode-encoded (\udddd notation) characters. native2ascii converts files which contain other character encodings into files containing Latin-1 and/or Unicode-encoded charaters.
If outputfile is omitted, standard output is used for output. If, in addition, inputfile is omitted, standard input is used for input.
OPTIONS
-reverse
Perform the reverse operation: convert a file with Latin-1 and/or Unicode encoded characters to one with native-encoded characters.
-encoding encoding_name
Specify the encoding name which is used by the conversion procedure. The default encoding is taken from System property file.encoding. The encoding_name string must be taken from the first column of the table of supported encodings in the Supported Encodings document.
-Joption
Pass option to the Java virtual machine, where option is one of the options described on the reference page for the java application launcher. For example, -J-Xms48m sets the startup memory to 48 megabytes. |
