查看: 8288|回复: 29
[资源共享] E-Book: 建立 Simwe 数学版 图书馆
发表于 2006-5-3 10:46:41 | 显示全部楼层 |阅读模式 来自 江苏无锡
E-Book: 建立 Simwe 数学版图书馆
上传 数学版 专业书籍 至 Simwe FTP   1 本 = + 2 分
Preface
It has long been the established policy of CRC Press to publish, in handbook form,
the most up-to-date, authoritative, logically arranged, and readily usable reference
material available. Prior to the preparation of this 31st Edition of the CRC Standard
Mathematical Tables and Formulae, the content of such a book was reconsidered.
The previous edition was carefully analyzed, and input was obtained from practitioners
in the many branches of mathematics, engineering, and the physical sciences.
The consensus was that numerous small additions were required in several sections,
and several new areas needed to be added.
Some of the new materials included in this edition are: game theory and voting
power, heuristic search techniques, quadratic elds, reliability, risk analysis and decision
rules, a table of solutions to Pell’s equation, a table of irreducible polynomials
a longer table of prime numbers, an interpretation of powers of 10, a collection
of “proofs without words”, and representations of groups of small order. In
total, there are more than 30 completely new sections, more than 50 new and modi
ed entries in the sections, more than 90 distinguished examples, and more than a
dozen new tables and gures. This brings the total number of sections, sub-sections,
and sub-sub-sections to more than 1,000. Within those sections are now more than
3,000 separate items (a de nition , a fact, a table, or a property). The index has also
been extensively re-worked and expanded to make nding results faster and easier;
there are now more than 6,500 index references (with 75 cross-references of terms)
and more than 750 notation references.
The same successful format which has characterized earlier editions of the Handbook
is retained, while its presentation has been updated and made more consistent
from page to page. Material is presented in a multi-sectional format, with each section
containing a valuable collection of fundamental reference material—tabular and
expository.
In line with the established policy of CRC Press, the Handbook will be kept as
current and timely as is possible. Revisions and anticipated uses of newer materials
and tables will be introduced as the need arises. Suggestions for the inclusion of new
material in subsequent editions and comments regarding the present edition are welcomed.
The home page for this book, which will include errata, will be maintained
The major material in this new edition is as follows:
Chapter 1: Analysis begins with numbers and then combines them into series and
products. Series lead naturally into Fourier series. Numbers also lead to functions
which results in coverage of real analysis, complex analysis, and generalized
functions.
Chapter 2: Algebra covers the different types of algebra studied: elementary algebra,
vector algebra, linear algebra, and abstract algebra. Also included are
details on polynomials and a separate section on number theory. This chapter
includes many new tables.
Chapter 3: Discrete Mathematics covers traditional discrete topics such as combinatorics,
graph theory, coding theory and information theory, operations re-
search, and game theory. Also included in this chapter are logic, set theory,
and chaos.
Chapter 4: Geometry covers all aspects of geometry: points, lines, planes, surfaces,
polyhedra, coordinate systems, and differential geometry.
Chapter 5: Continuous Mathematics covers calculus material: differentiation, integration,
differential and integral equations, and tensor analysis. A large table
of integrals is included. This chapter also includes differential forms and orthogonal
coordinate systems.
Chapter 6: Special Functions contains a sequence of functions starting with the
trigonometric, exponential, and hyperbolic functions, and leading to many of
the common functions encountered in applications: orthogonal polynomials,
gamma and beta functions, hypergeometric functions, Bessel and elliptic functions,
and several others. This chapter also contains sections on Fourier and
Laplace transforms, and includes tables of these transforms.
Chapter 7: Probability and Statistics begins with basic probability information (de n -
ing several common distributions) and leads to common statistical needs (point
estimates, con d ence intervals, hypothesis testing, and ANOVA). Tables of the
normal distribution, and other distributions, are included. Also included in this
chapter are queuing theory, Markov chains, and random number generation.
Chapter 8: Scientific Computing explores numerical solutions of linear and nonlinear
algebraic systems, numerical algorithms for linear algebra, and how to
numerically solve ordinary and partial differential equations.
Chapter 9: Financial Analysis contains the formulae needed to determine the return
on an investment and how to determine an annuity (i.e., the cost of a
mortgage). Numerical tables covering common values are included.
Chapter 10: Miscellaneous contains details on physical units (de nition s and conversions),
formulae for date computations, lists of mathematical and electronic
resources, and biographies of famous mathematicians.
It has been exciting updating this edition and making it as useful as possible.
But it would not have been possible without the loving support of my family, Janet
Taylor and Kent Taylor Zwillinger.
Daniel Zwillinger
DanielZwillinger@alum.mit.edu
15 October 2002
Download
SimWe FTP
 楼主| 发表于 2006-5-7 17:25:11 | 显示全部楼层 来自 江苏无锡
It's Free. Check below info for "How to best use Rapidshare".
发表于 2006-7-29 22:17:00 | 显示全部楼层 来自 陕西西安
强烈要求加分!
北大讲义---泛函分析(上);
北大讲义---泛函分析(上)。
均已上传!
发表于 2006-8-4 08:32:09 | 显示全部楼层 来自 北京朝阳
已上传六本书:
1.Apostol T M: Mathematical Analysis ,djvu,大小:9.98M
2.Ahlfors Lars:Complex Analysis,djvu,大小:5.12M
3.Arnold V I: Lectures on Partial Differential Equations,djvu,大小:1.68M
4.Heinz Hopf: Differential Geometry in the Large.,djvu,大小:1.4M
5.M Singer: Differential Equations and Computer Algebra,djvu,大小:2.17M
6.Kenneth Huffman , Ray Kunze : Linear Algebra,pdf,20.0M
请查收
发表于 2006-8-7 13:48:40 | 显示全部楼层 来自 北京丰台
以下十五本书已上传完毕:
1.Donald E Knuth:The.Art.of.Computer.Programming.Vol.4.(2001),pdf,大小:3.07M
2.Graham, Knuth, Patashnik:Concrete Mathematics,pdf,大小:11.2M
3.Greene D H, Knuth D E:Mathematics for the analysis of algorithms (3ed., Burkhauser, 1990),djvu,大小:834k
4.S.Timoshenko(铁木辛哥):材料力学,pdf,大小:11.7M
5.Taylor M E:Partial differential equations 1,djvu,大小:5.81M
6.Taylor M E:Partial differential equations 3,djvu,大小:6.11M
7.Hideyuki Matsumura: Commutative Algebra,djvu,1.96M
8.M F Atiyah, I G  MacDonald.:Introduction to Commutative Algebra,djvu,大小:1.18M
9.Nevanlinna R , Paatero V :Introduction To Complex Analysis ,djvu,大小:2.63M
10.J  Dieudonne:The Historical Development of Algebraic Geometry,djvu,大小:430k
11.Do Carmo:曲线和曲面的微分几何学,pdf,大小:14.9M
12.???:代数学,pdf,大小:20.0M
13.柯尔莫哥洛夫,佛明:函数论与泛函分析初步(上),pdf,大小:9.69M
14.柯尔莫哥洛夫,佛明:函数论与泛函分析初步(下),pdf,大小:7.55M
15.CV Westenholz:数学物理中的微分形式,pdf,大小:14.5M
请查收
发表于 2006-8-10 21:21:50 | 显示全部楼层 来自 同济大学
已经上传:
稀疏矩阵——算法及其程序实现
发表于 2006-8-11 11:47:34 | 显示全部楼层 来自 同济大学
已经上传:
数学名著译丛 常微分方程(阿诺尔德)
数学物理方法.卷1
数学物理方法.卷2
数学物理方程导论(C.A.克罗克斯顿)
发表于 2006-8-22 16:40:55 | 显示全部楼层 来自 上海
已经上传
NumericalMethods for Large Eigenvalue Problems (Y.saad)
发表于 2006-9-16 22:05:57 | 显示全部楼层 来自 陕西西安
已经上传:
矩阵论讲义-张凯院.rar
徐仲习题
发表于 2006-11-29 23:13:41 | 显示全部楼层 来自 安徽合肥
Abramowitz, Milton :           Handbook of mathematical functions with formulas, graphs, and mathematical tables
已上传
发表于 2007-11-13 07:27:10 | 显示全部楼层 来自 荷兰
已上传:
Elementary Differential Equations and boundry value problems 7th ed. - W. Boyce, R. Diprima
H—专业技术专区
[ 本帖最后由 spinoza1989 于 2007-11-13 00:49 编辑 ]
发表于 2007-11-13 07:43:48 | 显示全部楼层 来自 荷兰
已上传:
Matrices theory and applications  - Serre D.
H—专业技术专区
发表于 2008-5-17 17:03:53 | 显示全部楼层 来自 陕西西安
我有很多数学书,怎么上传?怎么进入?
负责人请讲讲
发表于 2008-5-20 09:05:02 | 显示全部楼层 来自 陕西西安
这的版主哪去了?怎没人回答?
发表于 2008-6-4 21:34:26 | 显示全部楼层 来自 安徽合肥
wow gold begola
Choose your server to buy wow gold and get gold delivered to you instantly! We strive to offer the fastest and most reliable service on the site for all your wow gold needs. Feel free to contact us 24 hours a day, 7 days a week by phone, live chat and email. Please contact with our live support for further details. The wow gold will deliver to you in a short while.
发表于 2009-4-21 15:46:07 | 显示全部楼层 来自 辽宁沈阳
都是好东西啊
发表于 2009-4-23 20:07:14 | 显示全部楼层 来自 江苏南京
晕,等级太低。。。
发表于 2010-2-19 15:23:48 | 显示全部楼层 来自 重庆
支持啊,在哪里下载呢?
发表于 2010-6-15 09:52:17 | 显示全部楼层 来自 上海长宁区
支持,不过请版主详细讲一下怎样下载呢?
发表于 2010-6-22 21:12:32 | 显示全部楼层 来自 大连理工大学
对呀,在哪里下载呀?
GMT+8, 2024-4-23 18:41 , Processed in 0.072309 second(s), 23 queries , Gzip On, MemCache On.
