我运行分析失败 好几个都是这样 怎么回事啊,下面是f06文件里的信息
*** SYSTEM INFORMATION MESSAGE 6916 (DFMSYN)
DECOMP ORDERING METHOD CHOSEN: BEND, ORDERING METHOD USED: BEND
*** USER INFORMATION MESSAGE 4158 (DFMSA)
---- STATISTICS FOR SPARSE DECOMPOSITION OF DATA BLOCK KLL FOLLOW
NUMBER OF NEGATIVE TERMS ON FACTOR DIAGONAL = 2
MAXIMUM RATIO OF MATRIX DIAGONAL TO FACTOR DIAGONAL = 1.5E+15 AT ROW NUMBER 482660
*** USER WARNING MESSAGE 4698 (DCMPD)
STATISTICS FOR DECOMPOSITION OF MATRIX KLL .
THE FOLLOWING DEGREES OF FREEDOM HAVE FACTOR DIAGONAL RATIOS GREATER THAN
1.00000E+07 OR HAVE NEGATIVE TERMS ON THE FACTOR DIAGONAL.
USER INFORMATION:
THIS MESSAGE MAY BE IGNORED IF NO GRID POINT IDS OR HIGH RATIO MESSAGES APPEAR IN THE TABLE ON THE NEXT PAGE.
USER FATAL MESSAGE 9050 (SEKRRS)
^^^ RUN TERMINATED DUE TO EXCESSIVE PIVOT RATIOS IN MATRIX KLL.
^^^ USER ACTION: CONSTRAIN MECHANISMS WITH SPCI OR SUPORTI ENTRIES OR SPECIFY PARAM,BAILOUT,-1 TO
CONTINUE THE RUN WITH MECHANISMS.
这个好像是你边界约束条件加的不够的关系,条件不够,方程组没办法求解,我计算的时候也遇到过。你看看在LOAD/BC里的位移约束条件有没有漏掉!
