- 2006-12-19
我把第一次计算后得到的dynain文件导入到第二步当做板坯时,不能计算是什么原因?以下是我的messag
文件,请老大帮我看一下。
Date: 01/31/2007 Time: 16:49:03
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Licensed to: |
| Platform : PC WIN32(PCWIN) |
| OS Level : WINDOWS XP |
| Hostname : ghmj007 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: f:/s/op20/1.dyn
The native file format : 32-bit small endian
Memory size from command line: 26214400
Memory option : AUTO selected
expanding memory to 26214400
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 250192
expanding memory to 480384
expanding memory to 762540
expanding memory to 807540
expanding memory to 837540
expanding memory to 1576116
expanding memory to 1638414
expanding memory to 1662920
expanding memory to 1683206
Open include file: 1.mod
expanding memory to 1726213
expanding memory to 1769213
expanding memory to 1812213
expanding memory to 1855213
expanding memory to 1898213
expanding memory to 1941213
expanding memory to 1984213
expanding memory to 2010213
expanding memory to 2036213
expanding memory to 2062213
expanding memory to 2586820
expanding memory to 2636667
expanding memory to 2686514
expanding memory to 2732540
expanding memory to 2778566
expanding memory to 2824592
expanding memory to 2974133
expanding memory to 3020159
expanding memory to 3070006
expanding memory to 4864506
expanding memory to 5723543
expanding memory to 5773390
expanding memory to 5819416
expanding memory to 5865442
expanding memory to 5957494
*** Warning add CONSTRAINED_ADAPTIVITY 441
Nodes 29336 29335 29337
*** Warning add CONSTRAINED_ADAPTIVITY 442
*** Warning add CONSTRAINED_ADAPTIVITY 443
Nodes 29362 29361 29363
*** Warning remove improper bounadry CONSTRAINED_ADAPTIVITY 105
Nodes 31848 26322 26323
*** Error can't find a right relation for CONSTRAINED_ADAPTIVITY 106
Nodes 31972 26323 26298
*** Error input data failed with: 1 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 0
Additional dynamically allocated memory: 0
Total: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 01/31/2007 16:49:03
End time 01/31/2007 16:49:07
Elapsed time 4 seconds ( 0 hours 0 minutes 4 seconds)
E r r o r t e r m i n a t i o n |
