- 2006-9-12
我做的是斗轮挖掘机的臂架,节点数不超过1W,导入到ADAMS中后在铰点的位置加了铰接的约束,
按道理在有重力的作用下,臂架会绕着铰点摆动,但是却出现以下的提示::
The greatest error in an equation is 9.25164E+14 in the
equation for FLEX_BODY model_1.FLEX_BODY_1 .
The greatest change in a variable is 1643.7 in the
variable for FLEX_BODY model_1.FLEX_BODY_1 .
Try the following in this order:
1. Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
or INTEGRATOR command to increase the maximum number of
iterations.
2. Temporarily change the value of the PATTERN argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
PATTERN = T.
3. Temporarily increase the value of the ERROR argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
time = 4.18752E-02 .
4. If one or more forces change rapidly or sharply near
time = 4.18752E-02, modify the force or forces.
做过以下的尝试:
1、怀疑是在ANSYS中的网格划分有问题,拿以前做的一个构件导入(节点数与臂架相当),在刚性点上加铰点,出现同样的问题
2、怀疑是因为构件的质量太大,把重力改小,结果仍然失败。
2、把铰点去掉,仿真成功,再将重力改小之后,仿真过程中可以看到构件自由落体时的颤动
3、去掉重力的情况下施加驱动提示“The joints of a gear, coupler, or motion may not have markers that
belong to a flexible body.”(疑问是在ANSYS中创建的刚性点不是属于柔性体吗?)
另外:我是在ADAMS/View中的build/flex body中导入的,需要在ADAMS/flex模块中进行什么操作吗?
困惑的感觉好难受啊.......
有哪位大侠能给小弟提示一下啊?
问题出在哪里呢?
附图:
[ 本帖最后由 cmi-likendo 于 2007-4-27 10:46 编辑 ] |
