- 39
- 2006-1-20
楼主 |
发表于 2007-5-19 10:54:59
来自 黑龙江哈尔滨
对于谐波分析,如何动画显示HUSM或BSUM呢?
ANHARM
Utility Menu > PlotCtrls > Animate > Time-Harmonic...
下面是个谐波分析的动画(help中的例子),有兴趣的可以看看
下面是Steve Groothuis (Micron Technology, Inc.)写的一个宏
- /com, Macro to create animation sequence of a harmonic analysis
- /com, Arg1 = 0 (H-field animation)
- /com, Arg1 = 1 (EF-field animation)
- !*ask,ssnum,The substep# you wish to animate,1
- !*ask,n,The number of frames per cycle,15
- ssnum=1
- n=15
- /post1
- *afun,deg
- lcdef,1,1,ssnum,0 ! real
- lcdef,2,1,ssnum,1 ! imaginary
- /com, *** get max and min values for contour intervals ***
- /graphics,full
- lcase,1
- nsort,h,sum
- *get,hremx,sort,,max
- *get,hremn,sort,,min
- nsort,ef,sum
- *get,efremx,sort,,max
- *get,efremn,sort,,min
- lcase,2
- nsort,h,sum
- *get,himmx,sort,,max
- *get,himmn,sort,,min
- nsort,ef,sum
- *get,efimmx,sort,,max
- *get,efimmn,sort,,min
- *if,hremx,gt,himmx,then
- hmax=hremx
- *else
- hmax=himmx
- *endif
- *if,hremn,lt,himmn,then
- hmin=hremn
- *else
- hmin=himmn
- *endif
- *if,efremx,gt,efimmx,then
- efmax=efremx
- *else
- efmax=efimmx
- *endif
- *if,efremn,lt,efimmn,then
- efmin=efremn
- *else
- efmin=efimmn
- *endif
- /graphics,power
- /com, *** Put graphics commands here to create plots ***
- /pbc,all,0
- /ctype,1
- /view,,1,1,1
- /plopts,minm,off
- /triad,off
- /gres,plot,gsav
- /expand,2,rect,half,,0.00001
- /dev,font,1,helvetica,medium,r,16,,,,,
- /com, *** Create looping of displays in time ***
- /seg,dele
- /seg,multi
- *do,theta,0,360-360/n,360/n
- real=cos(theta)
- imag=-sin(theta)
- lcfact,1,real
- lcfact,2,imag
- *if,real,eq,0,then
- lcfact,1,1e-10
- *endif
- *if,imag,eq,0,then
- lcfact,2,1e-10
- *endif
- lcase,1
- lcoper,add,2
- *if,arg1,eq,0,then
- /title, Contours of Magnetic Field Strength
- hinc=(hmax-hmin)/9*.05
- /contour,all,9,hmin,,hmax+hinc
- plnsol,h,sum
- *elseif,arg1,eq,1,then
- /title, Contours of Electric Field Strength
- efinc=(efmax-efmin)/9*.05
- /contour,all,9,efmin,,efmax+efinc
- plnsol,ef,sum
- *endif
- *enddo
- /seg,off
- !*ask,ncycles,The number of full period cycles,10
- !*ask,delay,Delay between successive frames,0.1
- ncycles=10
- delay=0.1
- anim,ncycles,1,delay
- /anfile,save,harm1,avi
- finish
复制代码
[ 本帖最后由 北极熊甲 于 2007-5-19 11:09 编辑 ] |
