- 1
- 2006-11-22
发表于 2008-5-27 21:28:13
来自 江苏徐州
回复 13# 的帖子
你的origin版本可能是7.0的,我在7.0上使用layer.x.ticksbydata$也是显示command error;
P.S.我又在origin6.0,5.0,4.0上尝试,都显示command error。layer.x.可能是LabTalk在origin7.5才新增加的语句和功能吧!
果然,在origin7.0的LabTalk Reference Version 7.0里面,是
layer.axis.spaceRead/write, numeric. Same as layer.axis.type.
layer.axis.thicknessRead/write, numeric. Width of axis in points.
layer.axis.ticksRead/write, numeric. Controls the major and minor ticks as follows: 0 = no ticks, 1 = major in, 2 = major out, 4 = minor in, and 8 = minor out. Numbers can be combined, so 3 = major ticks in and out.
layer.axis.toRead/write, numeric. Last axis scale value.
没有:layer.axis.ticksbydata$这个命令
在origin7.5的programming,LabTalk Language Reference才第一次出现这个命令。
layer.axis.TicksByData$
| Read/write, numeric
| Specifies a dataset to control tick mark position and labels.
[ 本帖最后由 jsswll 于 2008-5-27 21:54 编辑 ] |
