谢谢版主,那我把我的问题具体说一下,希望版主和各位大虾帮小妹一把!
问题描述:
两块永磁铁放置在三条平行的镍带两端对其进行磁化,为了增大三条镍带中的Y向磁感应强度BY,在两块永磁铁下面放置矩形磁芯。现在就是想优化磁芯的宽度(y向)和厚度(z向)使得镍带中的BY最大。设计变量为磁芯宽度W和磁芯厚度H,目标函数为三条镍带中的BY的总和的倒数。优化方法为零阶方法,可是在优化时,总会出现下面的Warning从而使得优化中断结束,换不同的尺寸模型,连框框里的数字大小都一样,奇怪。
*** WARNING ***
Unknown parameter name= _Z3. A value of 7.888609052E-31 will be used.
我也换过一阶方法,也出现同样的问题。我的镍带尺寸为8×25×0.15mm,很薄,划分网格的时候,
用的是Mesh Tool, 设置Global 中单元尺寸为0.0008m,不知道这样对于很薄的镍带怎样,可是不这样划分,又该怎样弄呢,或者是大家认为导致上面问题的原因到底是什么呢?
我的命令流:
/BATCH
/COM,ANSYS RELEASE 10.0 UP20050718
/TITLE,optimization of cores
*SET,W,0.004 磁芯初始宽度
*SET,H,0.004 磁芯初始厚度
*SET,HC,895000 永磁铁矫顽力
/PREP7
ET,1,SOLID96 定义单元
MPTEMP,,,,,,,,
MPTEMP,1,0 定义空气特性
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,250 定义镍带材料特性
TB,BH,3,1,24, 定义磁芯B-H曲线
TBPT,,405,0.80
TBPT,,468,0.90
TBPT,,550,1.0
TBPT,,670,1.1
TBPT,,840,1.2
TBPT,,1060,1.3
TBPT,,1223,1.35
TBPT,,1415,1.40
TBPT,,1722,1.45
TBPT,,2130,1.50
TBPT,,2671,1.55
TBPT,,3480,1.60
TBPT,,4496,1.65
TBPT,,5952,1.70
TBPT,,7650,1.75
TBPT,,10105,1.80
TBPT,,13000,1.85
TBPT,,15905,1.90
TBPT,,26296,2.0
TBPT,,32901,2.05
TBPT,,42700,2.10
TBPT,,61700,2.15
TBPT,,84295,2.20
TBPT,,110000,2.25
TB,BH,4,,30 定义永磁铁B-H曲线
tbpt,,355,.7
tbpt,,405,.8
tbpt,,470,.9
tbpt,,555,1.0
tbpt,,673,1.1
tbpt,,836,1.2
tbpt,,1065,1.3
tbpt,,1220,1.35
tbpt,,1420,1.4
tbpt,,1720,1.45
tbpt,,2130,1.5
tbpt,,2670,1.55
tbpt,,3480,1.6
tbpt,,4500,1.65
tbpt,,5950,1.7
tbpt,,7650,1.75
tbpt,,10100,1.8
tbpt,,13000,1.85
tbpt,,15900,1.9
tbpt,,21100,1.95
tbpt,,26300,2.0
tbpt,,32900,2.05
tbpt,,42700,2.1
tbpt,,61700,2.15
tbpt,,84300,2.2
tbpt,,110000,2.25
tbpt,,135000,2.3
tbpt,,200000,2.41
tbpt,,400000,2.69
tbpt,,800000,3.22
*CSET,1,2, 4,5,
MPCOPY, ,4,5
TBCOPY,ALL,4,5
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MGXX,4,,0 定义永磁铁矫顽力
MPDATA,MGYY,4,,0
MPDATA,MGZZ,4,,HC
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MGXX,5,,0
MPDATA,MGYY,5,,0
MPDATA,MGZZ,5,,-HC
BLOCK,-0.008,0.008,0.0125,0.0125+W,0,H, 建模磁芯1
BLOCK,-0.008,0.008,-0.0125,-0.0125-W,0,H, 建模磁芯2
BLOCK,-0.008,0.008,0.0125,0.0175,H,H+0.004, 建模永磁铁1
BLOCK,-0.008,0.008,-0.0125,-0.0175,H,H+0.004, 建模永磁铁2
BLOCK,-0.008,-0.004,-0.0125,0.0125,0,0.00015, 建模镍带1
BLOCK,-0.002,0.002,-0.0125,0.0125,0,0.00015, 建模镍带2
BLOCK,0.004,0.008,-0.0125,0.0125,0,0.00015, 建模镍带3
BLOCK,-0.018,0.018,-0.028,0.028,-0.008,0.02, 建空气
FLST,2,8,6,ORDE,2
FITEM,2,1
FITEM,2,-8
VOVLAP,P51X
FLST,5,3,6,ORDE,3
FITEM,5,6
FITEM,5,9
FITEM,5,-10
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ESIZE,0.0008,0, 定义镍带单元大小
MSHAPE,1,3D
MSHKEY,0
FLST,5,3,6,ORDE,3
FITEM,5,6
FITEM,5,9
FITEM,5,-10
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/VIEW,1,1
/ANG,1
/REP,FAST
FLST,5,2,6,ORDE,2
FITEM,5,13
FITEM,5,-14
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 3, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ESIZE,0,0
ESIZE,0.001,0, 定义磁芯单元大小
FLST,5,2,6,ORDE,2
FITEM,5,13
FITEM,5,-14
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
CM,_Y,VOLU
VSEL, , , , 11
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 4, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ESIZE,0.001,0,
CM,_Y,VOLU
VSEL, , , , 11
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
CM,_Y,VOLU
VSEL, , , , 12
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 5, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 12
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/VIEW,1,,,1
/ANG,1
/REP,FAST
CM,_Y,VOLU
VSEL, , , , 15
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ESIZE,0,0
ESIZE,0.005,0, 定义空气单元大小
CM,_Y,VOLU
VSEL, , , , 15
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
ANTYPE,0
MAGSOLV,2, , ,0.001,25,0
FINISH
/POST1
EPLOT
ALLSEL,ALL
FLST,5,3,6,ORDE,3
FITEM,5,6
FITEM,5,9
FITEM,5,-10
VSEL,S, , ,P51X
ESLV,S
ETABLE,EBY,B,Y 提取镍带中磁感应强度BY
SSUM
*GET,BYTOT,SSUM, ,ITEM,EBY
ALLSEL,ALL
*SET,OBJECT,1/BYTOT
! LGWRITE,'core','lgw','C:\DOCUME~1\yajie\',COMMENT
FINISH
/OPT
OPANL,'core','lgw',' '
OPVAR,H,DV,0.001,0.01, , 定义设计变量H
OPVAR,W,DV,0.001,0.01, , 定义设计变量W
/OPT
OPSAVE,'corevar','opt',' '
OPVAR,OBJECT,OBJ, , , , 定义目标函数
OPTYPE,SUBP 零阶优化
OPSUBP,30,7, 迭代次数
OPEQN,0,0,0,0,0,
OPEXE
