- 2007-9-10
楼主 |
发表于 2008-1-17 15:48:35
来自 浙江杭州
基于灰度值赋材料属性参考文献
谢谢鼓励!
提供一些参考文献 供大家参阅
Simpleware软件中用到的一些技术/算法 请参考一下文献:
If you would like to refer to papers in which the techniques/algorithms used in ScanIP/+FE/+CAD are purported to be explained,you might want to reference the following papers:
1 Tabor, G., Young, P.G., Beresford West, T., Benattayallah, A., 2007. Mesh Construction from Medical Imaging for Multiphysics Simulation: Heat Transfer and Fluid Flow in Complex Geometrics. Engineering Applications of Computational Fluid Mechanics, 1(2), 126-135.
2. Watson, I.G., Lee, P.D., Dashwood, R.J., Young, P. 2006. Simulation of the Mechanical Properties of an Aluminum Matrix Composite using X-ray Microtomography. Metallurgical and Materials Transactions A, 37A, 551-558.
3. Johnson, E.A.C., Young, P.G., 2005. On the use of a patient-specific rapid-prototyped model to simulate the response of the human head to impact and comparison with analytical and finite element models. Journal of Biomechanics, 38, 39-45.
Simpleware 生成体网格输出时 可基于灰度值赋材料属性 有关材料属性与原始H值的相互关系 请参考文献:
If you are looking for references for the relationship between bone material properties and original Hounsfield values, please find some references below:
1. Hobatho, Marie-Christine, Rho, Jac Y., Ashman, Richard B. “Anatomical Variation of Human Cancellous Bone Mechanical Properties In Vitro” Studies in Health Technology and Informatics, Vol. 40 (1997) 157-173
2. Rho, J.Y., Hobatho, M.C., and Ashman, R.B. “Relations of Mechanical Properties to Density and CT Numbers in Human Bone” Medical Engineering and Physics, Vol. 17, No. 5 (1995) 347-355
3.Taylor, W.R., Roland, E., Ploeg, H., Hertig, D., Klabunde, R., Warner, M.D., Hobatho, M.C., Rakotomanana, L., Clift, S.E. “Determination of Orthotropic Bone Elastic Constants Using FEA and Modal Anslysis” Journal of Biomechanics, Vol. 35 (2002) 767-773
4. McBroom, R.J., Hayes, W.C., Edwards, W.T., Goldberg, R.P., White, A.A. “Prediction of Vertebral Body Compressive Fracture using Quantitative Computed Tomography” Journal of Bone and Joint Surgery, Vol. 67-A, No. 8 (1985) 1206-1214
5.Hvid, Ivan, Bentzen, Soren M., Linde, Frank, Mosekilde, Lis, and Pongsoipetch, Buntoing. “X-Ray Quantitative Computed Tomography: The Relations to Physical Properties of Proximal Tibial Trabecular Bone Specimens” Journal of Biomechanics, Vol. 22, No. 8/9 (1989) 837-844
[ 本帖最后由 Jean_Huang 于 2008-1-18 08:29 编辑 ] |
