- 13
- 2005-7-26
楼主 |
发表于 2007-10-24 16:29:17
来自 黑龙江大庆
回复 #1 xcs2008 的帖子
翻译中有疑问之处:
Flow stress
流动应力
Hydrostatic tension spall model
静水拉力失效模式
Thus,the spalled material behaves as rubble
失效材料的行为有点像碎石
If hydrostatic tension is calculated then the pressure is reset to 0 for that element
如果计算了静水拉力,失效单元的压力值将被置为0
心得
Remark的内容主要是某一变量有多个选项时,解释每一选项的含义。或者对一些对数值计算上有特殊意义的变量给予解释。
文中提到“Constants for a variety of materials are provided in[Johnson and Cook 1983]”。在网上找到这样的帖子
2007-9-21 12:04 s0603076
寻求关于Johnson & Cook 模型的文章全文
A constitutive model and data for metals subjected to large strains, high rates and high temperatures
Johnson G R, Cook W H, Proc. 7th Intern Symp Ballistics, 1983
该篇文章未能找到。 |
