- 13
- 2006-7-1
楼主 |
发表于 2007-12-10 16:11:41
来自 湖北武汉
message文件
Date: 11/06/2007 Time: 20:59:37
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 07/30/2004 |
| Revision: 5434 Time: 15:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : BYB |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: CHANNEL.k
The native file format : 32-bit small endian
Memory size from default : 8500000
Memory option : AUTO selected
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2003 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 255424
expanding memory to 490848
expanding memory to 857124
expanding memory to 902124
expanding memory to 932124
expanding memory to 1686396
expanding memory to 1717414
expanding memory to 1778922
expanding memory to 1799420
expanding memory to 1823412
expanding memory to 2492318
expanding memory to 2550174
expanding memory to 2608030
expanding memory to 2668076
expanding memory to 2728122
expanding memory to 2788168
expanding memory to 2961736
expanding memory to 3021782
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna (version 970 ) date 07/30/2004
expanding memory to 7212
expanding memory to 108907
expanding memory to 414709
expanding memory to 3875114
expanding memory to 3932950
contracting memory to 3877634
expanding memory to 5971095
expanding memory to 5973226
expanding memory to 5982776
expanding memory to 6043148
expanding memory to 6046149
expanding memory to 6231871
expanding memory to 6231873
expanding memory to 7729149
contracting memory to 7635335
expanding memory to 8178289
expanding memory to 11941000
*** Warning Memory is set 3441000 words short
increase the memory size to 12500000
expanding memory to 12123544
expanding memory to 15292020
*** Warning Memory is set 2792020 words short
increase the memory size to 16500000
expanding memory to 16995189
*** Warning Memory is set 495189 words short
increase the memory size to 20500000
contracting memory to 16995189
expanding memory to 16995269
contracting memory to 16995269
expanding memory to 16995296
contracting memory to 16995296
expanding memory to 17578236
The LS-DYNA time step size should not exceed 0.173E-06
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
calculation with mass scaling:
scaled mass = 3.5610E-01
physical mass= 3.0546E+01
ratio = 1.1658E-02
1 t 0.0000E+00 dt 1.11E-07 flush i/o buffers
1 t 0.0000E+00 dt 1.11E-07 write ANSYS result file
5000 t 5.5489E-04 dt 1.11E-07 flush i/o buffers
10000 t 1.1099E-03 dt 1.11E-07 flush i/o buffers
15000 t 1.6649E-03 dt 1.11E-07 flush i/o buffers
20000 t 2.2199E-03 dt 1.11E-07 flush i/o buffers
25000 t 2.7749E-03 dt 1.11E-07 flush i/o buffers
25226 t 2.8000E-03 dt 1.11E-07 write ANSYS result file
30000 t 3.3299E-03 dt 1.11E-07 flush i/o buffers
35000 t 3.8849E-03 dt 1.11E-07 flush i/o buffers
40000 t 4.4399E-03 dt 1.11E-07 flush i/o buffers
45000 t 4.9949E-03 dt 1.11E-07 flush i/o buffers
50000 t 5.5499E-03 dt 1.11E-07 flush i/o buffers
50451 t 5.5999E-03 dt 1.11E-07 write ANSYS result file
55000 t 6.1049E-03 dt 1.11E-07 flush i/o buffers
60000 t 6.6599E-03 dt 1.11E-07 flush i/o buffers
65000 t 7.2149E-03 dt 1.11E-07 flush i/o buffers
70000 t 7.7699E-03 dt 1.11E-07 flush i/o buffers
75000 t 8.3249E-03 dt 1.11E-07 flush i/o buffers
75676 t 8.3999E-03 dt 1.11E-07 write ANSYS result file
80000 t 8.8799E-03 dt 1.11E-07 flush i/o buffers
85000 t 9.4349E-03 dt 1.11E-07 flush i/o buffers
90000 t 9.9899E-03 dt 1.11E-07 flush i/o buffers
95000 t 1.0545E-02 dt 1.11E-07 flush i/o buffers
99999 t 1.1100E-02 dt 1.11E-07 write d3dump01 file
100000 t 1.1100E-02 dt 1.11E-07 flush i/o buffers
100901 t 1.1200E-02 dt 1.11E-07 write ANSYS result file
105000 t 1.1655E-02 dt 1.11E-07 flush i/o buffers
110000 t 1.2210E-02 dt 1.11E-07 flush i/o buffers
115000 t 1.2765E-02 dt 1.11E-07 flush i/o buffers
120000 t 1.3320E-02 dt 1.11E-07 flush i/o buffers
125000 t 1.3875E-02 dt 1.11E-07 flush i/o buffers
126127 t 1.4000E-02 dt 1.11E-07 write ANSYS result file
130000 t 1.4430E-02 dt 1.11E-07 flush i/o buffers
135000 t 1.4985E-02 dt 1.11E-07 flush i/o buffers
140000 t 1.5540E-02 dt 1.11E-07 flush i/o buffers
145000 t 1.6095E-02 dt 1.11E-07 flush i/o buffers
150000 t 1.6650E-02 dt 1.11E-07 flush i/o buffers
151352 t 1.6800E-02 dt 1.11E-07 write ANSYS result file
155000 t 1.7205E-02 dt 1.11E-07 flush i/o buffers
160000 t 1.7760E-02 dt 1.11E-07 flush i/o buffers
165000 t 1.8315E-02 dt 1.11E-07 flush i/o buffers
170000 t 1.8870E-02 dt 1.11E-07 flush i/o buffers
175000 t 1.9425E-02 dt 1.11E-07 flush i/o buffers
176577 t 1.9600E-02 dt 1.11E-07 write ANSYS result file
180000 t 1.9980E-02 dt 1.11E-07 flush i/o buffers
185000 t 2.0535E-02 dt 1.11E-07 flush i/o buffers
190000 t 2.1090E-02 dt 1.11E-07 flush i/o buffers
195000 t 2.1645E-02 dt 1.11E-07 flush i/o buffers
199998 t 2.2200E-02 dt 1.11E-07 write d3dump02 file
200000 t 2.2200E-02 dt 1.11E-07 flush i/o buffers
201802 t 2.2400E-02 dt 1.11E-07 write ANSYS result file
205000 t 2.2755E-02 dt 1.11E-07 flush i/o buffers
210000 t 2.3310E-02 dt 1.11E-07 flush i/o buffers
215000 t 2.3865E-02 dt 1.11E-07 flush i/o buffers
220000 t 2.4420E-02 dt 1.11E-07 flush i/o buffers
225000 t 2.4975E-02 dt 1.11E-07 flush i/o buffers
227027 t 2.5200E-02 dt 1.11E-07 write ANSYS result file
230000 t 2.5530E-02 dt 1.11E-07 flush i/o buffers
235000 t 2.6085E-02 dt 1.11E-07 flush i/o buffers
240000 t 2.6640E-02 dt 1.11E-07 flush i/o buffers
245000 t 2.7195E-02 dt 1.11E-07 flush i/o buffers
250000 t 2.7750E-02 dt 1.11E-07 flush i/o buffers
252253 t 2.8000E-02 dt 1.11E-07 write ANSYS result file
255000 t 2.8305E-02 dt 1.11E-07 flush i/o buffers
260000 t 2.8860E-02 dt 1.11E-07 flush i/o buffers
265000 t 2.9415E-02 dt 1.11E-07 flush i/o buffers
270000 t 2.9970E-02 dt 1.11E-07 flush i/o buffers
275000 t 3.0525E-02 dt 1.11E-07 flush i/o buffers
277478 t 3.0800E-02 dt 1.11E-07 write ANSYS result file
280000 t 3.1080E-02 dt 1.11E-07 flush i/o buffers
285000 t 3.1635E-02 dt 1.11E-07 flush i/o buffers
290000 t 3.2190E-02 dt 1.11E-07 flush i/o buffers
295000 t 3.2745E-02 dt 1.11E-07 flush i/o buffers
299997 t 3.3300E-02 dt 1.11E-07 write d3dump03 file
300000 t 3.3300E-02 dt 1.11E-07 flush i/o buffers
302703 t 3.3600E-02 dt 1.11E-07 write ANSYS result file
305000 t 3.3855E-02 dt 1.11E-07 flush i/o buffers
310000 t 3.4410E-02 dt 1.11E-07 flush i/o buffers
315000 t 3.4965E-02 dt 1.11E-07 flush i/o buffers
320000 t 3.5520E-02 dt 1.11E-07 flush i/o buffers
325000 t 3.6075E-02 dt 1.11E-07 flush i/o buffers
327928 t 3.6400E-02 dt 1.11E-07 write ANSYS result file
330000 t 3.6630E-02 dt 1.11E-07 flush i/o buffers
335000 t 3.7185E-02 dt 1.11E-07 flush i/o buffers
340000 t 3.7740E-02 dt 1.11E-07 flush i/o buffers
345000 t 3.8295E-02 dt 1.11E-07 flush i/o buffers
350000 t 3.8850E-02 dt 1.11E-07 flush i/o buffers
353154 t 3.9200E-02 dt 1.11E-07 write ANSYS result file
355000 t 3.9405E-02 dt 1.11E-07 flush i/o buffers
360000 t 3.9960E-02 dt 1.11E-07 flush i/o buffers
365000 t 4.0515E-02 dt 1.11E-07 flush i/o buffers
370000 t 4.1070E-02 dt 1.11E-07 flush i/o buffers
375000 t 4.1625E-02 dt 1.11E-07 flush i/o buffers
378379 t 4.2000E-02 dt 1.11E-07 write ANSYS result file
380000 t 4.2180E-02 dt 1.11E-07 flush i/o buffers
385000 t 4.2735E-02 dt 1.11E-07 flush i/o buffers
390000 t 4.3290E-02 dt 1.11E-07 flush i/o buffers
395000 t 4.3845E-02 dt 1.11E-07 flush i/o buffers
399996 t 4.4400E-02 dt 1.11E-07 write d3dump04 file
400000 t 4.4400E-02 dt 1.11E-07 flush i/o buffers
403604 t 4.4800E-02 dt 1.11E-07 write ANSYS result file
405000 t 4.4955E-02 dt 1.11E-07 flush i/o buffers
410000 t 4.5510E-02 dt 1.11E-07 flush i/o buffers
415000 t 4.6065E-02 dt 1.11E-07 flush i/o buffers
420000 t 4.6620E-02 dt 1.11E-07 flush i/o buffers
425000 t 4.7175E-02 dt 1.11E-07 flush i/o buffers
428829 t 4.7600E-02 dt 1.11E-07 write ANSYS result file
430000 t 4.7730E-02 dt 1.11E-07 flush i/o buffers
435000 t 4.8285E-02 dt 1.11E-07 flush i/o buffers
440000 t 4.8840E-02 dt 1.11E-07 flush i/o buffers
445000 t 4.9395E-02 dt 1.11E-07 flush i/o buffers
450000 t 4.9950E-02 dt 1.11E-07 flush i/o buffers
454054 t 5.0400E-02 dt 1.11E-07 write ANSYS result file
455000 t 5.0505E-02 dt 1.11E-07 flush i/o buffers
460000 t 5.1060E-02 dt 1.11E-07 flush i/o buffers
465000 t 5.1615E-02 dt 1.11E-07 flush i/o buffers
470000 t 5.2170E-02 dt 1.11E-07 flush i/o buffers
475000 t 5.2725E-02 dt 1.11E-07 flush i/o buffers
479280 t 5.3200E-02 dt 1.11E-07 write ANSYS result file
480000 t 5.3280E-02 dt 1.11E-07 flush i/o buffers
485000 t 5.3835E-02 dt 1.11E-07 flush i/o buffers
490000 t 5.4390E-02 dt 1.11E-07 flush i/o buffers
495000 t 5.4945E-02 dt 1.11E-07 flush i/o buffers
499995 t 5.5499E-02 dt 1.11E-07 write d3dump05 file
500000 t 5.5500E-02 dt 1.11E-07 flush i/o buffers
504505 t 5.6000E-02 dt 1.11E-07 write ANSYS result file
505000 t 5.6055E-02 dt 1.11E-07 flush i/o buffers
510000 t 5.6610E-02 dt 1.11E-07 flush i/o buffers
515000 t 5.7165E-02 dt 1.11E-07 flush i/o buffers
520000 t 5.7720E-02 dt 1.11E-07 flush i/o buffers
525000 t 5.8275E-02 dt 1.11E-07 flush i/o buffers
529730 t 5.8800E-02 dt 1.11E-07 write ANSYS result file
530000 t 5.8830E-02 dt 1.11E-07 flush i/o buffers
535000 t 5.9385E-02 dt 1.11E-07 flush i/o buffers
540000 t 5.9940E-02 dt 1.11E-07 flush i/o buffers
545000 t 6.0495E-02 dt 1.11E-07 flush i/o buffers
550000 t 6.1050E-02 dt 1.11E-07 flush i/o buffers
554955 t 6.1600E-02 dt 1.11E-07 write ANSYS result file
555000 t 6.1605E-02 dt 1.11E-07 flush i/o buffers
560000 t 6.2160E-02 dt 1.11E-07 flush i/o buffers
565000 t 6.2715E-02 dt 1.11E-07 flush i/o buffers
570000 t 6.3270E-02 dt 1.11E-07 flush i/o buffers
575000 t 6.3825E-02 dt 1.11E-07 flush i/o buffers
580000 t 6.4380E-02 dt 1.11E-07 flush i/o buffers
580181 t 6.4400E-02 dt 1.11E-07 write ANSYS result file
585000 t 6.4935E-02 dt 1.11E-07 flush i/o buffers
590000 t 6.5490E-02 dt 1.11E-07 flush i/o buffers
595000 t 6.6045E-02 dt 1.11E-07 flush i/o buffers
599994 t 6.6599E-02 dt 1.11E-07 write d3dump06 file
600000 t 6.6600E-02 dt 1.11E-07 flush i/o buffers
605000 t 6.7155E-02 dt 1.11E-07 flush i/o buffers
605406 t 6.7200E-02 dt 1.11E-07 write ANSYS result file
610000 t 6.7710E-02 dt 1.11E-07 flush i/o buffers |
