- 2008-1-21
initial stress contributions are not included in stiffness matrix
maximum nodal temperature change per time step = 1.00000E+02
maximum nodal temperature change before reassembly = 1.00000E+02
recycle for properties when temperature estimation error exceeds 9.00000E+02
solution of non-positive definite equation systems will be forced
analysis will be continued if convergence has not been reached
control messages will be written to log file
parameters
parameters set as follows
predictor used for stress-strain calculation 1.00000E+00
penalty factor for boundary conditions 1.00000E+09
penalty for incompressibility - r-p flow 1.00000E+02
penalty for incompressibility - fluid flow 1.00000E+06
beta parameter for Newmark operator 2.50000E-01
gamma parameter for Newmark operator 5.00000E-01
gamma1 parameter for Single-Step-Houbolt 1.50000E+00
gamma parameter for Single-Step-Houbolt -5.00000E-01
sharp angle for sticking/separating - 2D 8.62500E+00
sharp angle for sticking/separating - 3D 2.00000E+01
initial strain rate for r-p flow 1.00000E-04
lowest strain rate cutoff for r-p flow 1.00000E-06
fraction of dilatational stress neglected 1.00000E+00
factor for drilling d.o.f for shells 1.00000E-04
factor for displacement after rezoning 1.00000E+00
universal gas constant 8.31400E+03
absolute temperature offset 2.73150E+02
thermal properties evaluation weight 5.00000E-01
surface projection factor in ssh dynamics 0.00000E+00
Stefan Boltzmann constant 5.67051E-11
Planck's second radiation constant 1.43877E-02
Speed of light in vacuum 2.99790E+08
maximum iterative displacement component 1.00000E+30
initial stiffness to simulate sticking 0.00000E+00
我是做拉拔工艺的,热力耦合,模拟老是不成功,敢问高手,这是什么问题
