- 2008-3-11
我在用 LS-DYNA 分析时出现了很多个 Error undefined node (但该节点我能看到啊)请高手帮忙解答一下
Date: 05/05/2008 Time: 19:37:33
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : 9c8b347f2bfd4d9 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: file.k
The native file format : 32-bit small endian
Memory size from default : 8500000
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 39680
expanding memory to 92630
expanding memory to 208190
expanding memory to 238190
expanding memory to 298190
expanding memory to 329208
expanding memory to 390708
expanding memory to 411862
expanding memory to 435372
expanding memory to 455372
expanding memory to 508767
expanding memory to 592962
*** Error in convert external to internal ELEMENT 25601 number 4654
contracting memory to 2
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna (version 970 ) date 01/10/2005
expanding memory to 3931
expanding memory to 41629
expanding memory to 51747
expanding memory to 234738
expanding memory to 238638
*** Error undefined node # 4654
4654 4689 4693 4658 4549 4650 4649 4550
input phase will continue if possible
*** Error undefined node # 4689
*** Error undefined node # 4693
*** Error undefined node # 4674
4674 4669 4670 4675 4618 4581 4580 4619
*** Error undefined node # 4669
*** Error undefined node # 6168
6169 6168 6231 6230 6345 6344 6298 6297
*** Error undefined node # 6231
*** Error undefined node # 6230
*** Error undefined node # 6345
*** Error undefined node # 6344
*** Error undefined node # 6298
*** Error undefined node # 6297
expanding memory to 298368
expanding memory to 422566
expanding memory to 424612
expanding memory to 426750
expanding memory to 431281
expanding memory to 434549
expanding memory to 485009
expanding memory to 513491
*** Warning number of master segments is zero.
expanding memory to 697760
contracting memory to 661022
expanding memory to 728229
expanding memory to 1128618
expanding memory to 1143146
expanding memory to 1507416
expanding memory to 1507470
expanding memory to 1707366
contracting memory to 1707366
expanding memory to 1707446
contracting memory to 1707446
expanding memory to 1707456
contracting memory to 1707456
input phase completed with 5760 fatal errors
please check messag file
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 1735826
Additional dynamically allocated memory: 12496
Total: 1748322 |
