- 59
- 2005-10-15
HM+NASTRAN做静力分析,PARAM经常如下设置:
PARAM,AUTOSPC,YES
PARAM,BAILOUT,-1
PARAM,COUPMASS,2
PARAM,K6ROT,100.0
PARAM,POST,-2
但在国外某汽车公司的网站上有如下notes:
PARAM,BAILOUT,-1
This card totally defeats all of Nastran built in checks and will prevents the job from reporting FATAL errors.
It will appear that your job has run correctly, but your answers will be erroneous.
You should never use this card unless specifically requested to by someone from MSC, or one of your local Technical Specialists.
PARAM,K6ROT,xxxEyyy
This card was originally invented to debug Nastran when the nonlinear analysis capabilities were being installed.
The original intent was to slow down the model and allow the nonlinear solution to converge.
In reality, there was an error in the original element formulation some 20 years earlier.
Eventually the element formulation error was found, but the card continues to be used.
Currently, users routinely place this card in their deck with no idea of where it came from or what it does.
They only know that if you have a model that will not run, this card will sometimes cause the model to produce answers. Please note, it will not necessarily cause the model to produce good answers, but it will sometimes produce answers.
The correct thing to do is to fix the model, and not to use cards like this to force printout.
请问大家一般怎么设置的? |
