- 9
- 2003-10-28
发表于 2008-7-4 18:41:15
来自 上海浦东新区
原帖由 odooa 于 2008-7-3 17:06 发表
對不起 我錯了
後來發現這個檔案根本無法完整執行
錯誤原因是
** Warnings found **
done now user system wallclock left left finished
% [hms] ...
在我的笔记本上没有问题,MADYMO R6.3.2 + Windows XP + 2 SMP CPUs
Started Fri Jul 04 15:38:32 2008
Running "D:/Program Files/Madymo/madymo_632\win32p\bin\translator_XML.exe" -r e_eevcwg13fe.xml
MADYMO/Translator_XML 6.3.2
Version : 6.3.2
Release date : 16:42:38 Nov 14 2006
(c) Copyright 2006, TNO MADYMO BV
All rights reserved
MADYMO (R) software including MADYMO (R) model libraries are confidential
information and proprietary products of TNO MADYMO BV, Delft, The Netherlands.
The terms and conditions governing the licensing of MADYMO (R) software
consist solely of those set forth in the written contracts between
TNO MADYMO BV or TNO authorised third parties and its customers. The software
may only be used or copied in accordance with the terms of these contracts.
MADYMO home page is located at http://www.tass-safe.com
This utility uses the XSLT processor xsltproc,
Copyright (C) 1998-2002 Daniel Veillard. All Rights Reserved.
Assessing 'e_eevcwg13fe.xml' ...
Assessing 'typedefs.xml' ...
Translation of 'D:/Program Files/Madymo/madymo_632\share\etc\typedefs.xml' is not required.
Assessing 'b_eevcwg13fe_inc.xml' ...
Translation of 'D:/Program Files/Madymo/madymo_632\share\dbs\barriers\b_eevcwg13fe_inc.xml' is not required.
Translation of 'D:\Program Files\Madymo\madymo_632\share\appl\3d\e_eevcwg13fe.xml' is not required.
Running "D:/Program Files/Madymo/madymo_632\win32p\bin\madymo3d.exe" -nrproc 2 -input e_eevcwg13fe.xml
MADYMO/Solver 6.3.2
Version : 6.3.2
Release date : 16:42:34 W. Nov 14 2006
All rights reserved
Running D:/PROGRA~1/Madymo/MADYMO~1\win32p\bin\bsaf.exe "e_eevcwg13fe.xml" "e_eevcwg13fe.saf"
Opening file 'D:\Program Files\Madymo\madymo_632\share\appl\3d\e_eevcwg13fe.xml'
Opening file 'D:/Program Files/Madymo/madymo_632\share\etc\mtd_3d.dtd'
Opening file 'D:/Program Files/Madymo/madymo_632\share\etc\mtd_3d_type.txt'
Opening file 'D:/Program Files/Madymo/madymo_632\share\etc\mtd_3d_range.txt'
Opening file 'D:/Program Files/Madymo/madymo_632\share\etc\typedefs.xml'
Opening file 'D:/Program Files/Madymo/madymo_632\share\dbs\barriers\b_eevcwg13fe_inc.xml'
Time elapsed: 19.734
Using Tree file : D:/Program Files/Madymo/madymo_632\share\etc\mtd_3d_paths.txt
Storage allocation:
4000000 words for integer storage
4000000 words for real storage
100000 words for character storage
% [hms] [hms] [hms]
0.0 15:41:35 35.5 27.7 176.1
0.7 15:42:05 60.6 29.5 205.9 4146 1:09:06 16:51:11
2.9 15:43:25 135.4 32.3 285.9 3521 0:58:41 16:42:06
5.7 15:45:23 245.4 36.9 403.5 4546 1:15:46 17:01:08
8.6 15:47:34 355.6 42.0 534.8 3666 1:01:06 16:48:40
10.0 15:48:28 410.3 44.2 589.2 3327 0:55:27 16:43:55
15.0 15:51:42 602.4 52.9 782.5 3933 1:05:33 16:57:14
17.1 15:53:12 692.1 55.4 872.8 3237 0:53:57 16:47:09
19.3 15:54:43 786.0 59.5 963.8 3955 1:05:55 17:00:38
20.0 15:55:24 826.1 60.4 1005.0 4606 1:16:46 17:12:10
20.7 15:56:13 875.5 62.5 1053.9 5208 1:26:48 17:23:01
24.3 16:00:19 1116.2 68.5 1299.9 6123 1:42:03 17:42:22
25.0 16:01:07 1165.6 70.3 1347.9 5041 1:24:01 17:25:08
30.0 16:06:46 1521.6 79.6 1686.7 4632 1:17:12 17:23:57
40.0 16:18:11 2185.5 99.3 2371.6 4095 1:08:15 17:26:25
41.4 16:19:41 2280.3 101.9 2461.4 3052 0:50:52 17:10:32
47.1 16:24:41 2665.8 111.5 2761.3 3102 0:51:42 17:16:22
48.6 16:26:00 2761.7 114.3 2840.6 2728 0:45:28 17:11:27
50.0 16:27:15 2855.7 116.7 2915.5 2588 0:43:08 17:10:22
60.0 16:36:02 3518.3 134.6 3443.1 1998 0:33:18 17:09:20
70.0 16:44:39 4182.4 151.4 3960.0 1533 0:25:33 17:10:12
80.0 16:53:23 4847.5 167.7 4483.7 975 0:16:15 17:09:38
83.6 16:56:21 5082.7 173.8 4662.2 724 0:12:04 17:08:25
85.7 16:57:48 5203.6 176.5 4749.1 571 0:09:31 17:07:19
90.0 17:00:44 5440.9 183.7 4925.0 395 0:06:35 17:07:19
97.9 17:06:13 5877.5 196.3 5253.3 100 0:01:40 17:07:52
100.0 17:07:45 5996.0 200.2 5345.5
Timing information:
CPU[sec] System[sec]
Initialisation ......................... 34.6( 1%) 25.4( 13%)
Element processing ..................... 3224.1( 54%) 7.1( 4%)
Element/Facet-Node/Vertex contact ...... 1466.5( 24%) 69.9( 35%)
Multibody-Node/Vertex contact .......... 0.0( 0%) 0.0( 0%)
Supports ............................... 68.7( 1%) 1.1( 1%)
Airbag thermodynamics .................. 0.0( 0%) 0.0( 0%)
External loads ......................... 49.5( 1%) 0.2( 0%)
Spotwelds/FE rigid bodies/constraints .. 206.5( 3%) 0.4( 0%)
FE time integration .................... 511.9( 9%) 4.4( 2%)
Total Finite Element.................... 5936.2( 99%) 93.4( 47%)
Total Multi Body ....................... 2.1( 0%) 3.0( 1%)
External program in coupling ........... 0.0( 0%) 0.0( 0%)
Output ................................. 23.0( 0%) 78.3( 39%)
Filtering and injury ................... 0.1( 0%) 0.1( 0%)
Total .................................. 5996.0(100%) 200.2(100%)
Begin problem time : 0.0000 ms
End problem time : 70.000 ms
Current problem time : 70.000 ms
Number of cycles : 7002 (multi body part)
Max. nr. of cycles : 64570 (FE model /2/1 ( /MDB_eevcwg13/Honeycomb_fem ) )
Number of CPU's : 2
Begin time : Fri Jul 04 15:38:39 2008
End time : Fri Jul 04 17:07:44 2008
Directory : D:\Program Files\Madymo\madymo_632\share\appl\3d
User : liuxj <liuxj@IBMX31>
Total CPU time : 5996.0 sec ( 1 hours 39 minutes 56 seconds)
Total elapsed time : 5345.5 sec ( 1 hours 29 minutes 5 seconds)
MADYMO TERMINATED NORMALLY, but 8861 warning(s) were found
Stopped Fri Jul 04 17:07:44 2008 |
