查看: 2844|回复: 22
[simpleware软件] simpleware 交流与讨论
发表于 2008-7-7 18:05:07 | 显示全部楼层 |阅读模式 来自 浙江杭州
         Simpleware三维建模软件基于核心的图像处理平台 ScanIP, 同时提供用于网格生成ScanFE模块和CAD植入的ScanCAD模块,为从三维图像转换成CAD/快速成形/有限元模型提供了世界领先的软件解决方案。
       既之前其独特的功能(如可对医学图像进行高效精确的图像分割直接生成四面体六面体混合体网格直接附材料属性自定义接触关系等)
       升级版本simpleware3.1 又在诸多方面功能得到进一步增强 现simpleware3.1 已正式发布:
http://www.simpleware.com/news.php
Simpleware launches New Release at WCCM VIIISimpleware is pleased to announce the release of Version 3.1 of ScanIP, +ScanFE and +ScanCAD, its advanced image processing and mesh generation software package, at the 8th World Conference on Computational Mechanics (WCCM VIII) 30 June - 4 July, 2008 in Venice, Italy.
The New Release offers many new and improved capabilities in image processing and mesh generation. Sophisticated new tools accelerate the process of segmenting and meshing 3D data. With this new software release, Simpleware extends its leadership in providing a complete solution for converting 3D scan data into CAD and CAE models.
New features of ScanIP and +ScanFE Version 3.1 include:
Algorithms and Export Options
New Mesh Refinement
  • User defined mesh refinement - zones of higher and lower mesh densities can now be easily and interactively selected.
  • Possibility to register (rotate and align) images.
  • Export of surface meshes in a new set of formats including: IGES, SAT, ANSYS, ABAQUS and PointsCloud.
  • Direct export of finite element models from +ScanFE to COMSOL.
User Interface & Usability
  • Improved visual feedback between the 2D slice position and the 3D view.
  • Option to crop datasets interactively.
  • Support for meshing up to 250 different masks/sub-domains.
  • Export of 3D view images in various formats (e.g. png, eps, etc.) for good quality print and presentations.
  • New fast preview option for quick rendering and visualization of 3D models.
  • Mask size estimator in ScanIP (e.g. number of voxels).
  • User control over the undo/redo option.
"ScanIP and +ScanFE Version 3.1 offers many new and exciting features that will significantly help our customers achieve faster image segmentation and obtain more accurate models," says Dr Rajab Said, Business Development Manager. "With Simpleware's range of software products, researchers and engineers have a powerful and robust image processing platform that enables them to produce high-fidelity analyses faster and more cost effectively."
[ 本帖最后由 Jean_Huang 于 2008-10-13 11:32 编辑 ]
 楼主| 发表于 2008-7-7 18:06:03 | 显示全部楼层 来自 浙江杭州
simpleware新版本信息
算法和输出选择增强功能:
&    用户自定义网格---可方便地选择相关区域设置不同密度的网格;
&    可对图像数据灵活进行旋转和移动等操作;
&    将表面网格以不同的格式输出 例如IGES/SAT/ANSNS/ABAQUSPointCloud
&    可将有限元模型直接输出到COMSOL;
&    新增多种高效过滤器
用户交互性操作:
&    二维切片和三维视图之间更好地定位,良好的视觉反馈;
&    交互式地剪切数据功能;
&    支持对250个不同的Mask或称子区域进行网格划分
&    可以不同的格式(例如.png,eps)输出三维图像,用于高质量的打印和演示;
&    可对三维模型进行快速显示预览,加快三维显示,节省内存消耗,加快建模速度
&    可在ScanIP中预估Mask的尺寸(例如得到体素的数量)
&    用户控制执行和撤销操作,自行控制内存资源,快速反应;
&    可从另外的.sip文件中导入Mask,不同文件之间Mask的导入导出,方便进行分工合作
采用新版本的simpleware
系统更加稳定 内存的消耗更少;用户能更快地进行图像分割,获得更加精确的模型
[ 本帖最后由 Jean_Huang 于 2008-8-8 00:11 编辑 ]
 楼主| 发表于 2008-7-7 19:01:17 | 显示全部楼层 来自 浙江杭州
simpleware三维建模软件补充介绍
更多信息 请参考:http://www.gaitech.net/cp6-1.asp   或 www.simpleware.com
[ 本帖最后由 Jean_Huang 于 2008-8-7 23:01 编辑 ]
发表于 2008-7-8 08:23:33 | 显示全部楼层 来自 福建福州
呵,好东西
呵,好东西。
发表于 2008-7-12 20:14:52 | 显示全部楼层 来自 浙江杭州
黄工辛苦了
期待新版本,功能更强大了
发表于 2008-7-17 19:20:53 | 显示全部楼层 来自 福建福州
新版本功能强大了不少,最起码可以建立很多个mask,二次编程就方便多了。希望在下一版本中能在scanFE模块中也加入透视功能。呵
 楼主| 发表于 2008-7-19 09:35:22 | 显示全部楼层 来自 浙江杭州
谢谢提出宝贵意见 !
欢迎大家免费试用simpleware 3.1  进一步体验simpleware新版本的特色
发表于 2008-7-20 13:31:14 | 显示全部楼层 来自 浙江杭州
不错,争取试用一下!
发表于 2008-8-6 21:45:50 | 显示全部楼层 来自 上海
好好东西,当然要顶一下了!
请问试用版怎样申请啊???
 楼主| 发表于 2008-8-7 08:41:39 | 显示全部楼层 来自 浙江杭州
目前simpleware公司授权上海硅步科学仪器有限公司全面负责simpleware软件在中国的服务 包括软件免费试用申请、技术服务以及代理销售等。
软件的免费试用 可以通过联络上海硅步科学仪器有限公司(Email: info@gaitech.net  Tel: 021-51098309)  进一步咨询;
联络好之后,硅步公司将免费寄送simpleware试用光盘;
收到光盘后在待安装simpleware软件的电脑上,运行安装程序setup.exe 将生成的Hostid文件(包括电脑名hostname和Hostid) 发送至: support@gaitech.net
同时注明使用者的相关信息 硅步公司便可帮忙申请simpleware免费试用License文件  通常来说 【免费的License 文件为一个月】
收到License之后 重新运行setup.exe文件 导入Lic 即可激活软件 开始试用
上海硅步科学仪器有限公司(www.gaitech.net)是一家生物力学领域的专业公司,Gaitech公司密切关注国际国内生物力学领域的最新研究进展,经常派代表参加国际会议特别是欧洲生物力学领域的会议,致力于将国际先进产品和先进理念传递到中国,同时和国内各科研院所密切合作,共同将中国的科研成果推向世界,进一步加速科研产品的产业化和国际化。
[ 本帖最后由 Jean_Huang 于 2008-8-7 16:52 编辑 ]
发表于 2008-8-7 08:52:33 | 显示全部楼层 来自 浙江杭州
多谢版主!
马上申请试用去。
发表于 2008-8-7 22:44:43 | 显示全部楼层 来自 上海浦东新区
我也要申请!
我很期待这个软件的非均匀网格划分功能,应该很有用!
[ 本帖最后由 youngrain 于 2008-8-7 22:45 编辑 ]
 楼主| 发表于 2008-8-7 23:30:06 | 显示全部楼层 来自 上海徐汇区
欢迎试用 亲自体验
新版本的用户自定义网格划分功能非常灵活 可给后续分析带来极大便利
 楼主| 发表于 2008-8-14 08:57:16 | 显示全部楼层 来自 浙江杭州
回复 6# fanguofan 的帖子
非常感谢对simpleware软件的使用提出好建议    有问题大家一起来讨论 相互交流 共同提供
有关simpleware软件的透视功能 宽泛地说 三个模块都具备 见附件图片
ScanIP 可以对各个部分进行透明显示
ScanFE 可以对各部分进行分割剪切 可看到内部的网格 【是否可以说 网格的透视就已达到目的】
ScanCAD可以对背景数据进行显示 而且可对各已分割的部分 假体等进行基于图像渲染技术的显示
[ 本帖最后由 Jean_Huang 于 2008-8-14 09:22 编辑 ]
发表于 2008-8-22 16:55:11 | 显示全部楼层 来自 浙江杭州
好强~~~~~~~~~~~··
:Q :Q
比我做的好,顶起来~
发表于 2008-10-11 15:49:13 | 显示全部楼层 来自 上海
第一次来这里,向黄工致敬!
试用过simpleware2.1的版本,感觉确实不错,简单易学,傻瓜式操作,很容易上手,如今看到有升级版的,而且增添了许多实用的功能,比如可以人工控制网格密度等,处理形状复杂的模型确实很强大,我也见过mimics,功能差不多,但没有simpleware来得简单方便。
不过对于cad模块和fe模块还有待极大提高,cad模块可以向proE,UG等cad软件学习,fe模块可以向truegrid,patran,hypermesh等网格划分软件学习。
对于自带的帮助文件,还有待进一步丰富,增加对更多功能的介绍,可以增加目录索引,搜索查询等功能。
话有点多了,以后常来看看!
 楼主| 发表于 2008-10-13 11:31:30 | 显示全部楼层 来自 浙江杭州
谢谢提出的宝贵意见!
simpleware 公司一直在致力于软件的不断更新与完善 期望聆听到来自客户更多的信息 以便在接下来的软件升级中 能更好地体现客户需求
若感兴趣的话 可以再次申请试用 体验一下simpleware3.1的快速建立精确模型
发表于 2009-8-21 14:42:30 | 显示全部楼层 来自 北京航空航天大学
友情帮顶!有机会可以写点关于mimics和simpleware的详细使用特点比较!
发表于 2011-10-27 12:29:49 | 显示全部楼层 来自 北京
好强~~~~~~~~~~~··
比我做的好,顶起来~
发表于 2012-4-30 10:47:42 | 显示全部楼层 来自 湖南长沙
正在申请试用,可恶的验证码
GMT+8, 2024-4-25 13:29 , Processed in 0.057401 second(s), 14 queries , Gzip On, MemCache On.
