查看: 130|回复: 3
[文件下载区] 求Johnson G R, Cook W H,的 fracture characteristics 全文
发表于 2008-11-13 18:44:57 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
求Johnson G R, Cook W H,的 fracture characteristics of three metals subjected to various strains,strain rates,temperratures and pressures全文
请有这篇文献的帮帮忙
谢谢
hitzhangzhuo@gmail.com
hitzhangzhuo@hotmail.com
发表于 2008-11-14 15:00:31 | 显示全部楼层 来自 大连理工大学
跟你查了一下,sciencedirect上没提供全文,只有下面的信息。
Fracture characteristics of three metals subjected to various strains, strain rates, temperatures and pressures
Engineering Fracture Mechanics, Volume 21, Issue 1, 1985, Pages 31-48
Gordon R. Johnson, William H. Cook
Preview   Related ArticlesAbstractAbstractAbstract
This paper considers fracture characteristics of OFHC copper, Armco iron and 4340 steel. The materials are subjected to torsion tests over a range of strain rates, Hopkinson bar tests over a range of temperatures, and quasi-static tensile tests with various notch geometries. A cumulative-damage fracture model is introduced which expresses the strain to fracture as a function of the strain rate, temperature and pressure. The model is evaluated by comparing computed results with cylinder impact tests and biaxial (torsion-tension) tests.
Article Outline
• References
发表于 2010-6-22 19:06:05 | 显示全部楼层 来自 重庆沙坪坝区
我也没找到这个论文,有人提供吗?
发表于 2011-4-8 12:55:16 | 显示全部楼层 来自 湖北武汉
同求这篇论文,专业人士请务必帮忙啊~~~
GMT+8, 2024-4-17 03:45 , Processed in 0.042372 second(s), 18 queries , Gzip On, MemCache On.
