- 2013-3-30
发表于 2013-5-30 14:24:54
来自 福建福州
asaki 发表于 2008-12-2 11:08
有人能把M文件导出成MPH文件吗
我这里一算就out of memory了
comsol中自带的《Introduction to COMSOL Multiphysics》中的扳手的例子中用了这个方法,不知是否算一个方法。 自己用过有效果,但是计算量过大,这个办法也没用。比如,我在Busbar例子中用过两次,前一次能实现,第二次无法实现。
粘贴复制下步骤,原理可能是用硬盘来做一些虚拟内存吧,猜的,呵呵。不过每个求解器好像最多只能提供512M。
You can easily solve this example model on a memory-limited machine by allowing
the solverto use the hard drive instead of performing all of the computation using
RAM. The steps below show how to do this. If your computer has more than
2 GB of RAM you can skip to the end of this section after step 5 below.
1. If you did not alr eady star t the computation, you can get access to the solver
settings fr om the Study node. In the Model Builder,right-click Study 1
and choose Show Default Solver .
2.Under Study 1>Solver Configurations,
expand the Solver 1 node
3.Expand the Stationary Solver 1 node
and left-click Dir ect .
A Direct solver is a fast and ver y r obust
type of solver that r equir es little or no
manual tuning in or der to solve a wide
range of physics pr oblems. The drawback
is that it may r equir e large amounts of
RAM.
4.In the Direct settings
window, in the General
section, select the
Out-of-cor e check box.
Leave the default
In-cor e memor y
(RAM) setting of
512 MB.
This setting ensures
that if your computer
runs low of RAM
during computation,
the solver will star t
using the har d drive as a
complement to RAM. Allowing the solver to use the har d drive instead of just
RAM will slow the computation down somewhat.
5.Right-click Study1 and select Compute (or pr ess F8).
After a few seconds of computation time, the default plot is displayed in the
Graphics window. You can find other useful information about the computation
in the Messages and Log windows; click the Messages and Log tabs under the
Graphics window to see the kind of information available to you. These windows
can also be opened from the main View menu.
