- 2008-9-17
发表于 2009-4-23 10:00:52
来自 湖北武汉
unconnected_regions是可以查看的
54# zsq-w
在6.8的版本里是可以设置查看的 可以通过修改环境变量或者在命令行输入命令的方式修改
command命令为 [unconnected_regions={yes}]
修改环境变量文件增加 unconnected_regions=ON
4.15 Element and node sets for unconnected regions of a model
Product: Abaqus/Standard
Benefits: You can now request element and node sets to be created for unconnected regions of a model.
Description: When constructing large and complicated models, it is possible to forget to properly connect some parts to the rest of the model through constraints, connectors, etc. To help identify such errors in models or to verify the number of unconnected regions in a model, Abaqus/Standard now provides a command line and environment variable—unconnected_regions—that controls the creation of element and node sets on the analysis output database for unconnected regions in the model during a datacheck analysis. Element and node sets created with this option are named MESH COMPONENT N, where N is the component number. |
