查看: 266|回复: 4
[错误和警告信息] 熱固耦合求解終止
发表于 2009-4-25 15:27:03 | 显示全部楼层 |阅读模式 来自 台湾
**** negative jacobian in element        16081
  called from:           3           8
**** negative jacobian in element        16381
  called from:           3           8
  called from:           3           8
**** negative jacobian in element        16481
  called from:           3           8
  called from:           3           8
**** negative jacobian in element        16781
  called from:           3           8
  called from:           3           8
*** Error - the solution has a non-positive definite
stiffnes matrix
     solution time                4.9000E+00
     time step size               1.0000E-01
suggestion - decrease time step
  105080 t 4.8000E+00 dt 1.00E+06 write d3plot file
E r r o r   t e r m i n a t i o n
這是我模擬求解時所出現的E r r o r
久久無法解決這個問題
貼部份K黨的設定
這是切削模擬  刀具為碳化鎢  工件為4043低碳鋼
*KEYWORD
*TITLE
*CONTROL_SOLUTION
         2
*CONTROL_THERMAL_SOLVER
        1         1         4         0         0         1       0.9
*CONTROL_THERMAL_TIMESTEP
         0       0.0     0.006     0.006         0         0
*CONTROL_CONTACT
         0         0         2         0         0         2         0
         0         0         0         0         0
         0         0         0         0         0
*INITIAL_TEMPERATURE_SET
         0        20
*DATABASE_FORMAT
         0
*MAT_JOHNSON_COOK
1,7.80,0.77
7.9E-3,5.1E-3,0.27,0.015,1.05,1.527E+3,20,1.1E-6
0.47E-5,-9.0,3.0,0.0,1.4,
  0.00
*EOS_GRUNEISEN
1,0.47,1.49,0.00,0.00,2.15,0.455,0.0
  0.00
*MAT_THERMAL_ISOTROPIC
         1      7.80        0         0
    465E-8    50E-15
*MAT_JOHNSON_COOK
2,7.80,0.77
0.47E-5,-9.0,3.0,0.0,0.8,
  0.00
*EOS_GRUNEISEN
2,0.47,1.49,0.00,0.00,2.15,0.455,0.0
  0.00
         2      7.80        0         0
    465E-8    50E-15
*MAT_JOHNSON_COOK
3,7.80,0.77
  0.00
*EOS_GRUNEISEN
3,0.47,1.49,0.00,0.00,2.15,0.455,0.0
  0.00
         3      7.80        0         0
    465E-8    50E-15
*MAT_JOHNSON_COOK
4,15.8,2.7
15.0E-2,1.7E-3,0.12,0.016,1.0,2.78E+3,20,1.1E-6
0.235E-5,-9.0,3.0,0.0,2.4,
  0.00
*EOS_GRUNEISEN
4,0.47,1.49,0.00,0.00,2.15,0.455,0.0
  0.00
4,15.8,0
245E-8,50E-15
*BOUNDARY_PRESCRIBED_MOTION_SET
4,1,-0.300E-02,1,1,0,0,0
*DEFINE_CURVE
  0.000000000000E+00 -0.300E-02
  1.084000000000E+00 -0.300E-02
  2.084500000000E+00 -0.300E-02
  3.084500000000E+00 -0.300E-02
  4.084500000000E+00 -0.300E-02
  6.084500000000E+00 -0.300E-02
  7.084500000000E+00 -0.300E-02
  8.084500000000E+00 -0.300E-02
  1.084500000000E+01 -0.300E-02
  2.084500000000E+01 -0.300E-02
  3.084500000000E+01 -0.300E-02
$                              CONTACT DEFINITIONS                             $
*CONTACT_ERODING_SURFACE_TO_SURFACE
         1         4         3         3         0         0         0         0
0.1500    0.1000     0.000     0.000     0.000             0 0.000    0.1000E+08
1.000     1.000     0.000     0.000     1.000     1.000     1.000     1.000
         0         1         0
         2         4         3         3         0         0         0         0
         0         1         0
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE
         3         4         3         3         0         0         0         0
$                              CONTROL OPTIONS                                 $
*CONTROL_ENERGY
         2         2         2         2
*CONTROL_SHELL
  20.0             1        -1         1         2         2         1
*CONTROL_TIMESTEP
    0.0000    0.9000         0  0.00      0.00
*CONTROL_TERMINATION
  30.0             0   0.00000   0.00000   0.00000
$                                 TIME HISTORY                                 $
*DATABASE_RCFORC
0.2000E-01
*DATABASE_BINARY_D3PLOT
0.4000E-01
*DATABASE_BINARY_D3THDT
0.2000E-01
*INITIAL_VELOCITY_GENERATION
         4         3  0.00    -0.600E-02  0.00      0.00
  0.00      0.00      0.00      1.00      1.00      1.00             0
 楼主| 发表于 2009-4-27 10:30:20 | 显示全部楼层 来自 台湾
頂一個  請幫幫我
 楼主| 发表于 2009-4-29 10:49:09 | 显示全部楼层 来自 台湾
有沒有版主或其他牛人可以幫幫我
給我一點點提示也行
 楼主| 发表于 2009-5-13 13:48:13 | 显示全部楼层 来自 台湾
有沒有哪位大大可以幫幫我
感恩不盡
发表于 2013-4-8 09:05:32 | 显示全部楼层 来自 山东青岛
你这个没有看见在接触的地方加接触啊……这样也可以么,求交流,最近也在做切削的温度耦合,遇到的问题很多啊
GMT+8, 2024-4-16 14:59 , Processed in 0.050294 second(s), 13 queries , Gzip On, MemCache On.
