- 2009-5-19
自己编写了一个MATLAB函数,comsol的扩散模型调用的时候出现错误,错误信息如下。哪位高人指点一下啊??拜托!!
错误: 6251
外部函数调用错误
- 函 数: deff
计算变量失败
- 变 量: Dxx_c_di
- 定 义 为: deff(c,1FFC2548)
计算表达式失败
- 表 达 式: diff(diff(((+(-Dxx_c_di*cx-Dxy_c_di*cy)*test(cx)+(-Dyx_c_di*cx-Dyy_c_di*cy)*test(cy)-+(+(Dts_c_di)*ct)*test(c))*dvol),{test@0}),cx)
Left- and right-hand sides are incompatible: Sizes are 1x1x1 and 1x288 respectively.
- Callstack: deff 19 n1(i,j,f)=0.5.*(C1(i,j,f)+sqrt(C1(i,j,f).^2+4.*ni.^2));
- Callstack: deff 18 if C1(i,j,f)<5*10
- Callstack: deff 17 for f=1:d
- Callstack: deff 16 for j=1:c
- Callstack: deff 15 for i=1:b
- Callstack: deff 2 C1=c.*0.602;%将c的单位mol/m3转换为e+18/cm3%
Exception:
java.lang.IllegalStateException: Parameter pairs already set.
(rethrown as com.femlab.util.FlFatalException)
(rethrown as com.femlab.jni.FlNativeException)
Fatal error.
- Type: IllegalStateException
- Callstack: deff 2 C1=c.*0.602;%cmol/m3e+18/cm3%
附deff函数:
- function De=deff(c,T)
- C1=c.*0.602;%将c的单位mol/m3转换为e+18/cm3%
- a=size(C1);
- b=a(1,1);
- c=a(1,2);
- g=length(a);
- if g==2
- d=1;
- else if g==3
- d=a(1,3);
- end
- end
- T1=T+273.15;
- ni=1800.*exp(-0.66./(0.026.*T1./300));
- for i=1:b
- for j=1:c
- for f=1:d
- if C1(i,j,f)<5*10
- n1(i,j,f)=0.5.*(C1(i,j,f)+sqrt(C1(i,j,f).^2+4.*ni.^2));
- else
- p=[1.6*(10^(-5)) 1.6*(10^(-5)).*C1(i,j,f) 1 -C1(i,j,f)];
- n2=roots(p);
- n1(i,j,f)=n2(3);
- end
- end
- end
- end
复制代码 |
