- 2003-9-9
Location of triad for tracking the rotation of the discrete beam element,
see the parameter CID below. The force and moment resultants in the
output databases are referenced to this triad. The flags -3.0, -1.0, 0.0,
1.0, and 3.0 are inactive if the option to update the local system is active
in the CID definition.
EQ.-3.0: beam node 1, the angular velocity of node 1 rotates triad,
EQ.-2.0: beam node 1, the angular velocity of node 1 rotates triad
but the r-axis is adjusted to lie along the line between the two beam
nodal points. This option is not recommended for zero length
discrete beams.,
EQ.-1.0: beam node 1, the angular velocity of node 1 rotates triad,
EQ. 0.0: centered between beam nodes 1 and 2, the average
angular velocity of nodes 1 and 2 is used to rotate the triad,
EQ.+1.0: beam node 2, the angular velocity of node 2 rotates triad.
EQ.+2.0: beam node 2, the angular velocity of node 2 rotates triad.
discrete beams.
EQ.+3.0: beam node 2, the angular velocity of node 2 rotates triad. |
