- 2004-11-5
楼主 |
发表于 2009-8-20 17:55:45
来自 新加坡
在我的MAX中,VISA始终有Waring,
error code:0x3FFF0077 (VI_WARN_CONFIG_NLOADED)
Description of error
viOpenDefaultRM returned 0x3FFF0077 (The specified configuration either does not exist or could not be loaded. VISA-specified defaults will be used.)
This error usually occurs when a Passport either could not be found or could not be loaded. All configured Passports were loaded correctly. Try refreshing the configuration tree to find your VISA resources. If this warning still appears, your VISA installation may be corrupted, and you may have to reinstall your software.
Possible reasons for this warning:
1. A Passport was either renamed or deleted.
2. A Passport depends on other components in your system that are no longer present.
3. Your installation of VISA is corrupt, i.e. an internal registry key is missing or changed.
4. An older installation of VISA may have caused this warning without specifying more information. Try refreshing the configuration tree to get more information.
不知怎样解决这个问题,望指教 |
