- 2009-4-24
发表于 2009-11-25 17:47:15
来自 黑龙江大庆
1# bageboshi
八哥博士,非常感谢您的分享,我画出了您给出的绳子,复制,bushing都做好了,但是仿真时出现了如下错误(电脑配置应该够,8g内存工程专用计算电脑),请指教,谢谢。
ERROR: ***** ADAMS MEMORY OVERFLOW *****
A larger MD array is required.
The error occurred in subroutine "SETUP" while allocating " INTE" space
from "SOLV" for the "NPOSR array".
Space Available: 30032 Space Requested: 78684
ADAMS/Solver requires more program memory to run this model.
Be aware that the above figures for Space available and Space
requested only reflect the current requirements. Additional space
may be required later in the solution process.
Several off-the-shelf memory configurations are available and
custom configurations may be created. The available memory models
and the corresponding array sizes are:
NAME MDSIZ
STANDARD 1,100,000
LARGE 3,000,000
EX-LARGE 10,000,000
HUGE 20,000,000
where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
the main memory array in ADAMS in words (one word is 4 bytes).
To use an alternative setting, you have to start the ADAMS 'Settings'
program. It can be found using the Start menu:
Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
folder of your ADAMS installation directory.
ERROR: Abnormal termination encountered in ADAMS/Solver. |
