Direct Femap Interface in ADINA — CFD Example One of our goals in the development of ADINA is to provide our users with interfaces to various pre- and post-processing packages. In the News of September 30, 2010, we announced the release of our direct Femap interface in ADINA. This interface is fully integrated into the Femap environment and communicates with Femap through its Application Programming Interface (API). For pre-processing, it is activated inside a Femap session and provides direct access to many ADINA capabilities. For post-processing, it can convert the ADINA results to a Femap neutral file format that can be imported into Femap directly. Below, we demonstrate an example of an ADINA CFD analysis using the Femap interface. A 3D turbulent flow around an intersection of two pipes is to be calculated, see Figure 1. In our numerical model, we use the k-ε turbulence model with FCBI-C elements. In addition to the prescribed velocity boundary conditions, turbulence boundary conditions are also applied at the inlet.
Figure 1 Schematic of the model
The following is a step-by-step description of the analysis, using the direct Femap interface in ADINA.
We want to illustrate how easily the interface is used, and
for this reason we give the details below.
Step 1: Create the model in Femap and mesh it with 3D tetrahedral elements The finite element mesh generated and obtained from Femap is shown below.
Step 2: Define the analysis settings Under Flow Assumptions, set the Flow Model to 'Turbulent K-Epsilon':
For the Element Formulation, set the Flow-Condition-Based Interpolation Element to 'FCBI-C'.
Step 3: Define the Turbulence K-Epsilon material
Step 4: Define the wall boundary condition
Step 5: Define the prescribed inlet velocity boundary condition
Step 6: Define the turbulence inlet boundary condition
Step 7: Define the turbulence initial condition
Step 8: Solve the model Enter the Job Name and Heading (if desired) in the ADINA CFD Analyze window, select options as shown, and thus run ADINA CFD to solve the model.
Step 9: Load the results through Femap neutral file Enter the Femap Neutral File name to load the results for post-processing.
Figures 2 and 3 show the results obtained from this analysis, visualized in the Femap interface.
Figure 2 Band plot of pressure
Figure 3 Band plot of total velocity
The entire analysis, from pre-processing to post-processing, was performed within the Femap environment using the direct Femap interface in ADINA. This allows users already familiar with Femap to adapt easily to analyses using ADINA, and thus significantly increases the number of available analysis options within Femap, including FSI. 28# businiao_good |
