- 2010-9-20
发表于 2010-12-13 21:37:03
来自 大连理工大学
Determinant (2x2x2 stencil)
The Determinant, more properly defined as the relative determinant, is the ratio of the smallest determinant of the Jacobian matrix divided by the largest determinant of the Jacobian matrix. In this option, the determinant at each corner of the hexahedron is found. A Determinant value of 1 would indicate a perfectly regular mesh element, 0 would indicate an element degenerate in one or more edges, and negative values would indicate inverted elements.
Determinant (3x3x3 stencil)
This option is the same as the 2x2x2 stencil, but edge midpoints of blocks are added to the Jacobian computation. |
