- 2006-2-19
楼主 |
发表于 2010-5-26 15:55:30
来自 江苏常州
Yes,the model is a example from the other people. but i copy this file into my computer! I've just had Ansys 12 installed on my computer, but have encountered other problem. I start a project, make a geometry, and define the dimension of the mesh, and then mesh the body,then the program freezes and produces this error message: "AnsysWBU.exe has encountered a problem. A diagnostic file has been written: d:\DOCUMENTS AND SET..... .....\Temp\AnsysWBDumpFile.dmp". Any idea whats wrong would be helpful, thanks in advance.
And if you want to see the problem description, you can enter my photo, it can be seen. Thank you! |
