- 34
- 2009-9-1
发表于 2010-9-30 23:45:08
来自 浙江杭州
vpg中的SBOXID和MBOXID什么意思啊?谢谢 。
chenqiang3311 发表于 2010-9-30 17:34
这是关键字*CONTACT中的两个变量。
SBOXID——Include in contact definition only those slave nodes/segments within box SBOXID (corresponding to BOXID in *DEFINE_BOX), or if SBOXID is negative, only those slave nodes/segments within contact volume |SBOXID| (corresponding to CVID in *DEFINE_CONTACT_VOLUME).A positive value of SBOXID can be used only if SSTYP is set to 2 or 3, i.e., SSID is a part ID or part set ID.
MBOXID ——Include in contact definition only those master segments within box MBOXID (corresponding to BOXID in *DEFINE_BOX), or if MBOXID is negative, only those master segments within contact volume |MBOXID| (corresponding to CVID in *DEFINE_CONTACT_VOLUME). A positive value of MBOXID can be used only if MSTYP is set to 2 or 3, i.e., MSID is a part ID or part set ID.
具体可以看LS-DYNA971用户手册。 |
