查看: 75|回复: 4
[K文件] 请问K文件中明明有状态方程,运行时却提示没有?
发表于 2010-11-15 17:44:50 | 显示全部楼层 |阅读模式 来自 江苏南京
我用ANSYS自带的solver运行K文件,出现下面错误:
*** Error material number          1 specified type=  9 requires
          an equation of state
*** Error material number          2 specified type=  8 requires
*** Error material number          4 specified type=  9 requires
input phase completed with    3 fatal errors
please check messag file
我的K 文件里1(炸药)2(水)、3(空气)号材料明明带有状态方程的啊(见下面),为什么还出现这样的错误呀?
*MAT_HIGH_EXPLOSIVE_BURN
1, 0.213E+04,7000,0.21E+11,0.0,0.0,0.0,0.0
*EOS_JWL
1,3.712E+10,3.231E+9,4.15,0.95,0.30,7.0E+9,1.0
*MAT_NULL
2,0.100E+04,0.0,0.0,0.0,0.0,0.0,0.0
*EOS_GRUNEISEN
2,1650,1.92,0.0,0.0,0.10,0.0,0.0
0.0
*MAT_NULL
3,1.293,0.0,0.0,0.0,0.0,0.0,0.0
*EOS_LINEAR_POLYNOMIAL
3,0.0,0.0,0.0,0.0,0.4,0.4,0.0
2.500E-06,1.0
*MAT_JOHNSON_HOLMQUIST_CONCRETE
4,0.245E+04,1.486E+10,0.79,1.6,0.007,0.0,3.63E+07
2.4E+06,1.0E-06,0.01,7.0,1.60E+07,0.001,0.8E+09,0.1
0.03,1.0,8.5E+10,-1.71E+11,2.08E+11,0.1
*MAT_PLASTIC_KINEMATIC
5,0.27E+04,4.55E+10,0.20,4.60E+07,4.0E+09,0.0
0.0,0.0,1.25,0.0
是不是我的PART号(见下)和状态方程的材料号没对好?
*PART
Part          1 for Mat         3 and Elem Type         1
         1         1         3         0         0         0         0
*PART
Part          2 for Mat         1 and Elem Type         1
         2         1         1         0         0         0         0
*PART
Part          3 for Mat         4 and Elem Type         1
         3         1         4         0         0         0         0
*PART
Part          4 for Mat         2 and Elem Type         1
         4         1         2         0         0         0         0
*PART
Part          5 for Mat         5 and Elem Type         1
         5         1         5         0         0         0         0
各位大侠、高手请帮我看一下到底是什么问题?怎么改?老板催得急啊!谢谢啦!
发表于 2010-11-15 17:51:15 | 显示全部楼层 来自 天津
*PART关键字中第4列代表EOSID,你的全是0,运行时肯定提示没有。把第四列改一下
发表于 2010-11-15 17:53:04 | 显示全部楼层 来自 天津
这种情况我也碰到过,我的解决方法:在ansys前处理中的材料模型用有状态方程的模型代替,比如JC,这样在k文件中修改模型的话,就不会有那样的错误
 楼主| 发表于 2010-11-15 20:06:15 | 显示全部楼层 来自 江苏南京
哦,谢谢楼上两位!
我去试一下。
发表于 2010-11-15 20:14:08 | 显示全部楼层 来自 天津
十分感谢二楼兄弟的回答,在K文件中修改十分方便,在前处理中选择有状态方程的材料模型,输出K文件,也就相当于修改了状态方程的ID号,两者的效果一样。
GMT+8, 2024-4-16 23:15 , Processed in 0.040692 second(s), 18 queries , Gzip On, MemCache On.
