- 10
- 2007-10-5
#include <stdio.h>
#include <string.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_sf.h>
#include <uf_part.h>
#include <uf_modl.h>
#include <uf_object_types.h>
#include <uf_disp.h>
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
if (irc)
char err[133],
msg[133];
sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
irc, line, file);
UF_get_fail_message(irc, err);
/* NOTE: UF_print_syslog is new in V18 */
UF_print_syslog(msg, FALSE);
UF_print_syslog(err, FALSE);
UF_print_syslog("\n", FALSE);
UF_print_syslog(call, FALSE);
UF_print_syslog(";\n", FALSE);
if (!UF_UI_open_listing_window())
UF_UI_write_listing_window(msg);
UF_UI_write_listing_window(err);
UF_UI_write_listing_window("\n");
UF_UI_write_listing_window(call);
UF_UI_write_listing_window(";\n");
return(irc);
#define WRITE_D(X) (write_integer_to_listing_window(#X, X))
static void write_integer_to_listing_window(char *title, int n)
char
msg[MAX_LINE_SIZE+1];
UF_CALL(UF_UI_open_listing_window());
sprintf(msg, "%s = %d\n", title, n);
UF_CALL(UF_UI_write_listing_window(msg));
/*ARGSUSED*/
static int mask_for_bodies(UF_UI_selection_p_t select, void *type)
UF_UI_mask_t
mask = { UF_solid_type, 0, UF_UI_SEL_FEATURE_BODY };
if (!UF_CALL(UF_UI_set_sel_mask(select,
UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC, 1, &mask)))
return (UF_UI_SEL_SUCCESS);
else
return (UF_UI_SEL_FAILURE);
static tag_t select_a_body(char *prompt)
int
resp;
double
cp[3];
tag_t
object,
view;
UF_CALL(UF_UI_select_with_single_dialog("Select a body", prompt,
UF_UI_SEL_SCOPE_WORK_PART, mask_for_bodies, NULL, &resp,
&object, cp, &view));
if (resp == UF_UI_OBJECT_SELECTED || resp == UF_UI_OBJECT_SELECTED_BY_NAME)
UF_CALL(UF_DISP_set_highlight(object, 0));
return object;
else return NULL_TAG;
static void do_it(void)
int
units;
tag_t
body,
material,
new_density,
new_poisson,
new_youngs,
part = UF_PART_ask_display_part();
UF_SF_material_prop_t
property_values;
if (UF_CALL(UF_PART_ask_units(part, &units))) return;
if ((UF_SF_locate_named_material("MYSTEEL", &material)) ||
(material == NULL_TAG))
if( units == UF_PART_METRIC )
UF_CALL(UF_MODL_create_exp_tag("206940000", &new_youngs));
UF_CALL(UF_MODL_create_exp_tag( "0.288", &new_poisson));
UF_CALL(UF_MODL_create_exp_tag("7.829e-006", &new_density));
else
UF_CALL(UF_MODL_create_exp_tag("30000091.8", &new_youngs));
UF_CALL(UF_MODL_create_exp_tag("0.288", &new_poisson));
UF_CALL(UF_MODL_create_exp_tag("0.000731", &new_density));
UF_CALL(UF_SF_init_matl_prop( &property_values));
property_values.isotropic.youngs_modulus.type =
UF_SF_MULTI_PROP_EXPRESSION;
property_values.isotropic.youngs_modulus.multi.expression_tag =
new_youngs;
property_values.isotropic.poissons_ratio.type =
property_values.isotropic.poissons_ratio.multi.expression_tag =
new_poisson;
property_values.isotropic.mass_density.type =
property_values.isotropic.mass_density.multi.expression_tag =
new_density;
UF_CALL(UF_SF_create_material ("mySteel", "myMETAL",
UF_SF_MATERIAL_ISOTROPIC, &property_values, UF_SF_MATL_IS_EDITABLE,
&material));
UF_SF_free_matl_prop(&property_values);
WRITE_D(material);
while ((body = select_a_body("Apply mySteel material")) != NULL_TAG)
UF_CALL(UF_SF_link_material(material, body));
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int paramLen)
if (UF_CALL(UF_initialize())) return;
do_it();
UF_terminate();
int ufusr_ask_unload(void)
return (UF_UNLOAD_IMMEDIATELY);
