- 2010-10-3
file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/491364194/QQ/WinTemp/RichOle/9OQ$F4_LE{`TNZN)GD~Y]X0.jpg
梁的两端往复位移加载,最大位移是40mm,加载步如下,钢筋采用桁架单元,梁柱采用三维实体单元。网格单元大小50mm,荷载条件是:柱的上下端为固定铰支即U1=U2=U3=0,UR1=0,柱顶受10N/mm2的均布压力,分析步:时间长度为1,最大增量步数为200,初始增量步大小为0.001,最小1e-7,最大是1。相互作用:梁柱接触截面采用tie,内部钢筋采用embeded。混凝土本构关系中,混凝土损伤塑性数据为:
受拉行为
2400000 | 0 | 1960000 | 0.0001 | 1500000 | 0.0003 | 1290000 | 0.0004 | 1080000 | 0.0005 | 723000 | 0.0008 | 484000 | 0.001 |
受压行为
18200000 | 0 | 22100000 | 0.0004 | 24000000 | 0.0008 | 24500000 | 0.0012 | 23000000 | 0.002 | 21600000 | 0.0024 | 16600000 | 0.0036 | 11300000 | 0.005 |
钢筋的塑性(本构)
加载步如下:
时间 | 位移 | 0 | 0 | 0.02 | 0.1 | 0.04 | 0 | 0.06 | -0.1 | 0.08 | 0 | 0.1 | 0.2 | 0.12 | 0 | 0.14 | -0.2 | 0.16 | 0 | 0.18 | 0.3 | 0.2 | 0 | 0.22 | -0.3 | 0.24 | 0 | 0.26 | 0.4 | 0.28 | 0 | 0.3 | -0.4 | 0.32 | 0 | 0.34 | 0.5 | 0.36 | 0 | 0.38 | -0.5 | 0.4 | 0 | 0.42 | 0.6 | 0.44 | 0 | 0.46 | -0.6 | 0.48 | 0 | 0.5 | 0.7 | 0.52 | 0 | 0.54 | -0.7 | 0.56 | 0 | 0.58 | 0.7 | 0.6 | 0 | 0.62 | -0.8 | 0.64 | 0 | 0.66 | 0.85 | 0.68 | 0 | 0.7 | -0.85 | 0.72 | 0 | 0.74 | 0.9 | 0.76 | 0 | 0.78 | -0.9 | 0.8 | 0 | 0.82 | 0.95 | 0.84 | 0 | 0.86 | -0.95 | 0.88 | 0 | 0.9 | 1 | 0.92 | 0 | 0.94 | -1 |
最后出现的警告是:
For *tie pair (assembly__pickedsurf517-assembly__pickedsurf516), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf519-assembly__pickedsurf518), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Degree of freedom 5 is not active in this model and can not be restrained
Degree of freedom 6 is not active in this model and can not be restrained
The plasticity/creep/connector friction algorithm did not converge at 4 points
The plasticity/creep/connector friction algorithm did not converge at 1 points
The plasticity/creep/connector friction algorithm did not converge at 5 points
导致出现错误:
Time increment required is less than the minimum specified
Abaqus/Standard Analysis 由于出错而退出 - 如果 消息 文件存在, 请从该文件中获得可能的错误消息.
请问以上是什么原因导致的啊?上面的警告看不懂什么意思!!!敬请高手指教!!!! |
