- 2009-5-3
发表于 2012-1-4 06:59:14
来自 美国
zsq-w你好!我最近尝试用connector模拟非线性弹簧功能(要拉压方向具有对称的非线性,以后再定义不对称拉压)。单独受拉可以实现。同时定义拉压属性时,就没有成功。我试了cartesian和axial这两种connector,都没有成功。当我定义负方向(受压)的elastic和plastic本构后,根本不能计算。
The executable D:\SIMULIA\Abaqus\6.10-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
报错让我联系abaqus公司。
我把帮助文件看了好几遍,没有看到这方面有何特殊限制或要求。只看到了一个功能connector uniaxial behavior可能有用,但只写着abaqus/explicit,那就是只能在explicit里用吧。
我看了你以前发的帖子用connector模拟非线性弹簧,但你定义的只是受拉,不知道你有没有尝试过拉压功能都有的非线性弹簧。谢谢! |
