- 2010-7-27
楼主 |
发表于 2011-1-10 21:20:33
来自 马来西亚
小弟没用cae提交任务。。因为inp 文件里用了cae 不支持的命令。。symmetric model generation 和symmetric result transfer..
小弟查了.dat 文件。。是节点错误造成这问题吗?
PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
*symmetricresultstransfer, step=1, inc=4
OPTIONS BEING PROCESSED
*Heading
SYMMETRIC RESULTS TRANSFER FOR TIRE MODEL
*symmetricmodelgeneration, revolve, nodeoffset=500, elementoffset=500
START OF SYMMETRIC MODEL GENERATION
READING RESTART FILE GENERATED ON RELEASE 6.10-1 DATE 09-Jan-20 TIME 22:13:59
THE TOLERANCE USED IN SYMMETRIC MODEL GENERATION IS 0.0000
***NOTE: THE MESH WILL BE CONNECTED ON THE REFERENCE PLANE.
***ERROR: Node 2 does not belong to instance 'PART-1-1' and cannot be assigned
to instance node set 'ASSEMBLY_REINFORCE-1_MEM-2BELTS'
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION |
