- 2010-1-3
发表于 2011-1-17 16:13:50
来自 陕西西安
finish
/prep7
cmsel,s,d_3
f,all,heat,200
allsel,all
cmsel,s,c_6
f,all,heat,400
allsel,all
cmsel,s,m_9
f,all,heat,400
allsel,all
tunif,22
kbc,1
neqit,25
finish
/prep7
我的代码是上面这样的,怎么还是出现下面这个warning呢。(我把热传导的代码删掉了,热传导的代码该咋写啊)
USE A MAXIMUM OF 1 EQUILIBRIUM ITERATIONS EACH SUBSTEP
*** WARNING *** CP = 2.281 TIME= 16:22:28
Using 1 iteration per substep may result in unconverged solutions for
nonlinear analysis and the program may not indicate divergence in this
case. Check your results. 还弹出了两个同样的warning
*** WARNING *** CP = 1.797 TIME= 16:27:34
SOLVE is not a recognized BEGIN command, abbreviation, or macro. This
command will be ignored.
我没加热传导的话没有error,只有上面的三个warning可是并没有解出来,solution前面那个对号没出来,还是个闪电。。 |
