- 10
- 2007-10-5
#include <stdio.h>
#include <string.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_sf.h>
#include <uf_modl.h>
#include <uf_disp.h>
#include <uf_obj.h>
#include <uf_sf_types.h>
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
if (irc)
char err[133],
msg[133];
sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
irc, line, file);
UF_get_fail_message(irc, err);
/* NOTE: UF_print_syslog is new in V18 */
UF_print_syslog(msg, FALSE);
UF_print_syslog(err, FALSE);
UF_print_syslog("\n", FALSE);
UF_print_syslog(call, FALSE);
UF_print_syslog(";\n", FALSE);
if (!UF_UI_open_listing_window())
UF_UI_write_listing_window(msg);
UF_UI_write_listing_window(err);
UF_UI_write_listing_window("\n");
UF_UI_write_listing_window(call);
UF_UI_write_listing_window(";\n");
return(irc);
#define WRITE(X) UF_UI_open_listing_window(); UF_UI_write_listing_window(X)
static logical prompt_for_a_number(char *prompt, char *item, double *number)
int
irc,
resp;
char
menu[1][16];
double
da[1];
strncpy(&menu[0][0], item, 16);
menu[0][15] = '\0';
da[0] = *number;
resp = uc1609(prompt, menu, 1, da, &irc);
if (resp == 3 || resp == 4)
*number = da[0];
return TRUE;
else return FALSE;
/*ARGSUSED*/
static int mask_for_cae_bodies(UF_UI_selection_p_t select, void *type)
UF_UI_mask_t
mask = { UF_caegeom_type, UF_caegeom_body_subtype, 0 };
if (!UF_CALL(UF_UI_set_sel_mask(select,
UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC, 1, &mask)))
return (UF_UI_SEL_SUCCESS);
else
return (UF_UI_SEL_FAILURE);
static int select_cae_bodies(char *prompt, tag_t **cae_bodies)
int
cnt,
ii,
resp;
UF_CALL(UF_UI_select_with_class_dialog("Select Polygon Bodies", prompt,
UF_UI_SEL_SCOPE_WORK_PART, mask_for_cae_bodies, NULL, &resp, &cnt, cae_bodies));
for (ii = 0; ii < cnt; ii++)
UF_CALL(UF_DISP_set_highlight((*cae_bodies)[ii], FALSE));
return cnt;
static void do_it(void)
tag_t
*bodies,
mesh = NULL_TAG;
UF_SF_ugs_tet_mesh_parms_t
mesh_parms;
double
e_sz = 25.4;
char
buf[133];
int
n;
if (((n = select_cae_bodies("Select bodies to mesh", &bodies)) > 0)&&
prompt_for_a_number("Enter Element Size", "Element Size", &e_sz))
mesh_parms.midnodes = TRUE;
mesh_parms.element_size = 25.4;
mesh_parms.midnode_option = 2;
mesh_parms.maximum_midnode_jacobian = 0;
mesh_parms.minimum_face_angle = 20.0;
mesh_parms.surf_mesh_size_variation = 0;
mesh_parms.tet_mesh_size_variation = 20;
UF_CALL(UF_SF_create_ugs_tet_mesh(&mesh_parms, n, bodies, &mesh ));
if(mesh == NULL_TAG)
UF_UI_write_listing_window("Mesh not created, check parameters\n");
else
sprintf(buf, "New mesh tag: %d\n", mesh);
UF_UI_write_listing_window(buf);
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int paramLen)
if (UF_CALL(UF_initialize())) return;
do_it();
UF_terminate();
int ufusr_ask_unload(void)
return (UF_UNLOAD_IMMEDIATELY);
